Browse Forums Building A New House 1 Feb 25, 2019 7:40 pm Hi all, Swapping our floor plan to the below design. Is there anything you would add/change? We’re also struggling to decide between the bottom two facades. Any advice is greatly welcomed. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Building Plan advice 2Feb 25, 2019 8:08 pm Hi, Couple of ideas (but not sure how simple to achieve?): - flip door location to PWD and flip internals to reduce direct line of sight to toilet etc - having access to Alfresco via lounge, not as useful as via dining. Maybe a hinged door from dining? - not sure you need a window to pantry? We have one in our new design but not sure we made the best call there - I would probably rather access store from main living, rather than rumpus - careful with fridge door opening into pantry door/wall....make sure it will open - maybe swap upstairs WIL and WC...so bedroom doesn’t look direct at toilet Anyhow there are some initial thoughts. Nothing too major, and some of this is just personal preference. --------------------------------------------------------------------- Check our Homeone build blog here Re: Building Plan advice 3Feb 25, 2019 8:30 pm darb74 Hi, Couple of ideas (but not sure how simple to achieve?): - flip door location to PWD and flip internals to reduce direct line of sight to toilet etc - having access to Alfresco via lounge, not as useful as via dining. Maybe a hinged door from dining? - not sure you need a window to pantry? We have one in our new design but not sure we made the best call there - I would probably rather access store from main living, rather than rumpus - careful with fridge door opening into pantry door/wall....make sure it will open - maybe swap upstairs WIL and WC...so bedroom doesn’t look direct at toilet Anyhow there are some initial thoughts. Nothing too major, and some of this is just personal preference. Thank you so much! Great advice. Didn’t even think of the WIL and WC! Versaloc is a mortarless besser block system that still needs a properly engineered footing. If you just do a 400x200 footing it will fail in time. At 17m long you need it… 1 18273 i thought the flipped plan initially but bec i want narrow pathway from entry to dining (dont like bend), also cannot fit the… 7 17286 5 10494 |
