Browse Forums Building A New House 1 Feb 24, 2019 10:40 pm Re: Termite Barrier visible 2Feb 25, 2019 8:18 am I'm pretty sure it has to be visible, because if you cover it up with something like mortar then the termites have got something to use as a bridge over the barrier! However … and maybe someone more knowledgeable than I can comment … that bottom photo looks to me as though there's a big hole in the barrier? It doesn't look right to me. Also in the other two shots it looks like it's at the same level as the concrete (I think it's the little flash of blue at the bottom of the wall?) whereas I thought the termite barrier was supposed to be at least a little bit above ground level? Hi, I had a barrier reef pool installed less that 2 years ago and the gel coat is already fading. The colour is electric grey shimmer which isn’t available… 0 3817 I’m not a structural engineer but I’m free. you still need an engineer for the plans. I only have part of your plans, but you seem to have a 850mm drop from the side… 3 9944 DIY, Home Maintenance & Repair Hi, I have an old fence/barrier made of treated pine logs bolted to plates and these are bolted to very large metal posts/girders. The plates and bolts are rusted through… 0 15111 |
