Browse Forums Building A New House 1 Feb 15, 2019 4:43 pm Hi All, What would you recommend if there was a gap in between the window frame and the bricks. I know that an infill can be added to the top of the frame. Would that affect the insulation of the window frame if only an infill is added versus no gap at all? I've seen the same in almost all windows of the house Note: The house hasn't been handed over to me yet. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Building with Metricon - Gap between brick and window fr 2Feb 15, 2019 5:16 pm asahi_home Hi All, What would you recommend if there was a gap in between the window frame and the bricks. I know that an infill can be added to the top of the frame. Would that affect the insulation of the window frame if only an infill is added versus no gap at all? I've seen the same in almost all windows of the house Note: The house hasn't been handed over to me yet. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ The fill it with foal insulation and then add a strip of aluminium the same colour as your windows. Ours is the same. But they have just finished a few and we have a few to go 2 4916 Its the flashing and is normal. Some builders cover them up others just leave them handing. You can cover it up with an aluminium bracket or ask the builder. 7 8401 The gap can be adjusted so it's tighter. You can definitely set up corner cabinets to have the same gap as standard doors. 2 8594 |
