Browse Forums Building A New House Re: Our first home build Sorrento 39 with Carlisle homes 41Jun 21, 2019 6:51 pm Roof tiles are done. It is good to see they managed to do it quickly as possible even in bad weather. I was worrying about rain soaking all the wood and first floor boards. Site supervisor asking for the frame inspection report but even after three days NHI didn't send the report yet. No idea why they are taking so long to compile a few page report which are mostly pictures! Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Our first home build Sorrento 39 with Carlisle homes 43Jun 22, 2019 3:57 pm Macher Did you get termite protection? C is powering along on you job. Thanks Macher! Yes they are working fast even on Saturdays I could see people working on site. We got termite protection in contract but not sure when it is get installed or how it is done. Re: Our first home build Sorrento 39 with Carlisle homes 44Jun 22, 2019 4:07 pm We got the frame inspection report from NHI, and this where I really see the benefit of having expert opinion on a new build. They have found fair few issues of the frame construction. While most of them are minor and easily fixable there are couple of issues that might be a problem. They found frame bottom plate is overhanging the slab in some areas as much as 40mm in some locations and secondly slab honeycombing issues on some edges. I have now forwarded this to C and SS and see how they going to sort this one out. Not very happy with it atm. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Our first home build Sorrento 39 with Carlisle homes 45Jun 30, 2019 3:02 pm Builder is in the process of fixing issues highlighted by the inspector and now have done this to fix the frame overhanging issue at the front wall. They have dynabolted some treated pine to the slab and according to them it is their engineered approved solution. Not sure how reliable this solution is even though I have seen some others doing the same. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Our first home build Sorrento 39 with Carlisle homes 47Jul 02, 2019 2:34 pm Your site is so clean compared to my dumping ground. C doing very well. M same problem but the instruction from the surveyor was to add structural grout to build out the slab to remove over hang. Partner is super happy with this solution as stuctual grout is stronger than the concrete slab. Re: Our first home build Sorrento 39 with Carlisle homes 48Jul 03, 2019 9:34 am Macher Your site is so clean compared to my dumping ground. C doing very well. M same problem but the instruction from the surveyor was to add structural grout to build out the slab to remove over hang. Partner is super happy with this solution as stuctual grout is stronger than the concrete slab. Yeah they cleaned the site recently after completion of the frame stage. It is really hard to believe these builders and their supervisors can't manage a simple but critical issue like frame overhanging. This is a very common problem and these are not custom homes they must have done the same house many many times over and over but still can't get the hang of it. We blame Chinese products for lack of quality control but even they can it right after couple of iterations, honestly can't believe these things happening with these cookie cutter mass produce builders! I asked C to do the same with concrete repair cement but they say this is their engineer approved solution (may be easiest and cheapest) , however I asked them send us the engineer certified report so we can cross check with an independent structural engineer. Re: Our first home build Sorrento 39 with Carlisle homes 49Jul 06, 2019 8:28 am We fought back with C to check the overhang correction again and also to send us the proper rectification details from Engineer so we and NHI can check that it has done properly. We got the rectification details from Engineer and he only recommend non shrinking grout upto 20 mm overhang and up-to 45mm overhang H3 class treated pine dynabolt to the slab. They have done that but some pegs are not tightly wedge between bottom plates and slab, we have ask them to fix that. Also need to find out Pine they have used is proper H3 treated ones. Also there is the steel beam overhang at the front garage corner (same amount as front wall) as well they have tried to get away with Pine wood but according to Engineer this must be corrected with 30mm thick steel plates and concrete. SS has promised to fix that issue. They have used some non shrinking grout on internal garage wall overhang we are happy with that. NHI is going there Monday for inspection and SS has promised everything will be ready by then, fingers crossed! Re: Our first home build Sorrento 39 with Carlisle homes 50Jul 06, 2019 8:49 am Ramee We fought back with C to check the overhang correction again and also to send us the proper rectification details from Engineer so we and NHI can check that it has done properly. We got the rectification details from Engineer and he only recommend non shrinking grout upto 20 mm overhang and up-to 45mm overhang H3 class treated pine dynabolt to the slab. They have done that but some pegs are not tightly wedge between bottom plates and slab, we have ask them to fix that. Also need to find out Pine they have used is proper H3 treated ones. Also there is the steel beam overhang at the front garage corner (same amount as front wall) as well they have tried to get away with Pine wood but according to Engineer this must be corrected with 30mm thick steel plates and concrete. SS has promised to fix that issue. They have used some non shrinking grout on internal garage wall overhang we are happy with that. NHI is going there Monday for inspection and SS has promised everything will be ready by then, fingers crossed! Wow, what a shame you have had such a battle on your hands so early in the build. I hope it all gets sorted for you! Keep fighting! Re: Our first home build Sorrento 39 with Carlisle homes 51Jul 06, 2019 12:26 pm shokel1975 Wow, what a shame you have had such a battle on your hands so early in the build. I hope it all gets sorted for you! Keep fighting! Yeah thanks shokel1975, It was a very stressful period knowing it is not right and they care less about rectifying things properly, we wont give up! At least we need Engineer rectification properly implemented. Re: Our first home build Sorrento 39 with Carlisle homes 52Jul 06, 2019 5:21 pm Despite issues with rectification Hebel, plaster board and insulation are on site ready to go. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ They have used grout in internal garage wall overhang that is a positive sign Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Our first home build Sorrento 39 with Carlisle homes 53Jul 06, 2019 7:29 pm Ramee Builder is in the process of fixing issues highlighted by the inspector and now have done this to fix the frame overhanging issue at the front wall. They have dynabolted some treated pine to the slab and according to them it is their engineered approved solution. Not sure how reliable this solution is even though I have seen some others doing the same. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ And how does the Termite Protection Warranty align with the fix? Re: Our first home build Sorrento 39 with Carlisle homes 54Jul 06, 2019 11:19 pm kks And how does the Termite Protection Warranty align with the fix? Hi kks, very good question, normally H3 pine is resistent to termite attack. I am mostly worrying about moisture and wood degradation in time. I have friends willing to replace all the pegs with steel if C allows us to do so. Going to ask Monday from SS. Re: Our first home build Sorrento 39 with Carlisle homes 56Jul 07, 2019 4:34 pm kks That is exterior wall? More an issue of edge breeching and concealed routing for termites than degradation. Yeah it is the front wall! There is the portico slab under the pegs so they are not directly sitting closer to soil. However that is what house original design engineer has recommended and C just following that.. Re: Our first home build Sorrento 39 with Carlisle homes 57Jul 11, 2019 8:35 am Now builder has accepted the mistake and fixed the issue with front garage corner steel column overhang according to engineer rectification details. Not the best looking fix but hope it is functional. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Tried to get the C to get other pine pegs removed and replaced with steel but site supervisor not willing to do it even after we said we will supply all the material and labour costs. He just keep saying he can't deviate from what approved by the engineer. May be we will do that after handover! Next issue was found by our independent inspector doing pre plaster inspection saying pine pegs are not properly treated according to the engineer requirements. Those pegs even though H3 level treated, need to be retreated the cut ends before go in but builder hasn't done it. SS said he will get in to it but I have my doubts as hebel work has already started and no way to check that afterwords. Re: Our first home build Sorrento 39 with Carlisle homes 58Jul 13, 2019 4:19 pm Sneak peeked into the house today to see any progress... wow they have done lots of plastering on internal walls and Hebel cladding started on outside as well. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Our first home build Sorrento 39 with Carlisle homes 59Jul 13, 2019 6:29 pm Ramee Sneak peeked into the house today to see any progress... wow they have done lots of plastering on internal walls and Hebel cladding started on outside as well. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Wow it is flying along! It is so great to see the plaster up... you really get a good feel for the rooms now 😀 So it looks like we finally have some movement on site! Definitely later than expected, but I'll take any progress at this point. I'll drop by over the weekend to get… 5 27716 We were lucky in that our old house was so small (86 square metres) compared to the new house, they were able to take enough readings around the old backyard house before… 8 37143 Carlisle use to sneak a water resistant "Performance Solution" into their contracts. Have you checked your contract for same? 4 10223 |
