Browse Forums Building A New House Re: Our first home build Sorrento 39 with Carlisle homes 5May 10, 2019 10:30 am Mark Armstrong BSc (Eng) MIEAust CPEng Development Manager http://www.katanafoundations.com.au http://www.polyvoid.com.au http://www.biax.com.au Re: Our first home build Sorrento 39 with Carlisle homes 12May 13, 2019 2:27 pm Mark Armstrong BSc (Eng) MIEAust CPEng Development Manager http://www.katanafoundations.com.au http://www.polyvoid.com.au http://www.biax.com.au Re: Our first home build Sorrento 39 with Carlisle homes 16May 17, 2019 10:03 am Ramee Today went to see the construction site to see some screw pile action but it was already done and gone when I arrived. They must have done really quick or start very early considering amount of piles have to screw in to the ground! Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ You should be able to put a tape measure down the piles and confirm they all go to the correct depth - what depth is natural ground? Mark Armstrong BSc (Eng) MIEAust CPEng Development Manager http://www.katanafoundations.com.au http://www.polyvoid.com.au http://www.biax.com.au Re: Our first home build Sorrento 39 with Carlisle homes 18May 17, 2019 5:51 pm Engineer You should be able to put a tape measure down the piles and confirm they all go to the correct depth - what depth is natural ground? From borehole logs from soil test report, one borehole data reports natural sand start around 1m mark. Other four boreholes data reports 30cm to 50cm deep from surface. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ I managed to get the screw pile data logs as well. There are totally 48 screw piles all going same depth of 4m with apparently 2 helix design? All record same SWL and Nm. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Our first home build Sorrento 39 with Carlisle homes 19May 17, 2019 6:24 pm Macher Looks like we are in sync. Same day site start and today we had drains installed too. Slab pour scheduled next Thursday! Hi Macher, Oh that is great news! Yes our slab pour is scheduled on next Thursday as well..! I didn't see your build thread until now! Your's going to be really great house! Congrats!! Hoping both out slab pours go according to the plan! Re: Our first home build Sorrento 39 with Carlisle homes 20May 20, 2019 8:58 am Ramee Engineer You should be able to put a tape measure down the piles and confirm they all go to the correct depth - what depth is natural ground? From borehole logs from soil test report, one borehole data reports natural sand start around 1m mark. Other four boreholes data reports 30cm to 50cm deep from surface. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ I managed to get the screw pile data logs as well. There are totally 48 screw piles all going same depth of 4m with apparently 2 helix design? All record same SWL and Nm. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Looks good - not sure how you get exactly the same reading on every pile at 4.0m as there will always be a bit of variation - but on the face of it - it looks good. Mark Armstrong BSc (Eng) MIEAust CPEng Development Manager http://www.katanafoundations.com.au http://www.polyvoid.com.au http://www.biax.com.au So it looks like we finally have some movement on site! Definitely later than expected, but I'll take any progress at this point. I'll drop by over the weekend to get… 5 27716 We were lucky in that our old house was so small (86 square metres) compared to the new house, they were able to take enough readings around the old backyard house before… 8 37143 Carlisle use to sneak a water resistant "Performance Solution" into their contracts. Have you checked your contract for same? 4 10233 |
