Browse Forums Building A New House Re: New home build - Custom Design WA 101Oct 07, 2019 9:24 am Wow, your house look good, but a bit slow. Mine is full brick 2 storey started in August and the builder said it should be finished by February, the contract time frame is April 20. We are at the roof stage now, and the work is continue 5 days a week so far, weather been good so far!! I checking on the work almost every 2nd day after work and We never have any problem getting in the site to look, even builder invite in and if anything does not look right we ask builder immediately. Even the we currently encounter problem with upper floor suspended concrete (in situ type) thickness not even, and try to see why, also we plan to lay solid timber floor on upper level but forgot to tell builder before the upper floor concrete poured, so now have to work with builder to level the wet area so both same level at the end. Building house is exciting but also headaches at the same time. Re: New home build - Custom Design WA 102Oct 07, 2019 10:06 am Sanders2 Wow, your house look good, but a bit slow. Mine is full brick 2 storey started in August and the builder said it should be finished by February, the contract time frame is April 20. We are at the roof stage now, and the work is continue 5 days a week so far, weather been good so far!! I checking on the work almost every 2nd day after work and We never have any problem getting in the site to look, even builder invite in and if anything does not look right we ask builder immediately. Even the we currently encounter problem with upper floor suspended concrete (in situ type) thickness not even, and try to see why, also we plan to lay solid timber floor on upper level but forgot to tell builder before the upper floor concrete poured, so now have to work with builder to level the wet area so both same level at the end. Building house is exciting but also headaches at the same time. Re: New home build - Custom Design WA 104Oct 07, 2019 8:22 pm Sanders2 I am in Sydney metro through !! Dimah construction. They organized, and line up Tradies. Btw, how to upload photo ??? Re: New home build - Custom Design WA 106Oct 12, 2019 12:49 pm This week the dry wall and ceilings were installed on the ground floor. The remaining window frames were installed - I'm loving the look of the commercial frames going all the way to the ceiling. The render was continued around the exterior of the ground floor and the roof cover over the garage was also commenced. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: New home build - Custom Design WA 110Oct 18, 2019 9:02 am Sanders2 How does it look??? My builder just asked what ceiling style I want and he suggested shadow line!!! Re: New home build - Custom Design WA 111Oct 18, 2019 11:12 am Ok, thanks and good to know, I go with this option !!!! Your house look so good with that open space ceiling !!! Mine, I was not account for plumbing work and my house first floor is in situ concrete, so now I loose 30cm to ground ceiling height to 1 of the living room. Wish I knew this when designing the house. Good luck to us with the rest of the work !! Re: New home build - Custom Design WA 112Oct 18, 2019 9:05 pm Sanders2 Ok, thanks and good to know, I go with this option !!!! Your house look so good with that open space ceiling !!! Mine, I was not account for plumbing work and my house first floor is in situ concrete, so now I loose 30cm to ground ceiling height to 1 of the living room. Wish I knew this when designing the house. Good luck to us with the rest of the work !! But even then, one of our plumbing wastes was dropped below the ceiling level, and had to be fixed. Re: New home build - Custom Design WA 113Oct 19, 2019 11:54 am More plastering was worked on this week, including the plaster float and external render. The glazing on the residential grade windows was also installed on the ground floor. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: New home build - Custom Design WA 115Oct 19, 2019 2:49 pm Your Good good !!!, outside look like a finished home. Mine still look raw, render to outside start Monday, then moulding, at the moment window and door are installing, spa baths arrive and install next week as well. Kitchen just measured today, all electrical tube as well as air cond vent/pipe running just finished. Counting down !!!! Re: New home build - Custom Design WA 116Oct 19, 2019 2:59 pm amilelka More plastering was worked on this week, including the plaster float and external render. The glazing on the residential grade windows was also installed on the ground floor. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: New home build - Custom Design WA 119Oct 25, 2019 7:12 pm The oversized sliding doors were installed this week. The staircase window is still requiring installation before lockup next week. A plasterer was on site today flushing the drywall joints and starting on the shadowline cornices downstairs. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ ideal house depends on the site and location as much as internal floor plan....what is the distance from the house to all four boundaries, where is north, describe your… 3 15142 6 55311 So it looks like we finally have some movement on site! Definitely later than expected, but I'll take any progress at this point. I'll drop by over the weekend to get… 5 27321 |
