Browse Forums Building A New House Re: New home build - Custom Design WA 31Mar 22, 2019 8:42 pm Yes I saw that comment. I have heard that you need a minimum of 3c height of brickwork over an opening, but I don't know if it has to be 3 separate bricks. Did you ask your supervisor about it? Re: New home build - Custom Design WA 32Mar 22, 2019 8:50 pm Didn’t get a chance to unfortunately. I checked out photos of other people’s builds and saw that they had the same as us, which is 3 courses of single course brick on exterior windows and door frames and above other internal steel lintels but not on internal doors, so I didn’t question it. I read that internal door frames are certified to not require lintels, due to the strength of the top of the frame, but I don’t know how true that is. Re: New home build - Custom Design WA 33Mar 22, 2019 10:20 pm Maybe the requirements for internal walls are different since they're braced by the ceiling? I also haven't noticed 3 bricks being used above door frames on other sites, so I hope it's fine. Re: New home build - Custom Design WA 34Mar 22, 2019 10:27 pm The use of 3 courses of single bricks is for not required over standard steel frames. It's used over steel lintels because they flex and single course bricks are stronger and don't cause cracking if the lintel deforms slightly. Once the opening is above a certain size they will also rod the the bed joints for additional strength. Accessible Carpentry & Cabinets accessiblecarpentry@gmail.com accessiblecarpentry.com.au https://www.facebook.com/pages/Accessible-Carpentry-Cabinets/583314911709039 Re: New home build - Custom Design WA 35Mar 22, 2019 10:33 pm chippy The use of 3 courses of single bricks is for not required over standard steel frames. It's used over steel lintels because they flex and single course bricks are stronger and don't cause cracking if the lintel deforms slightly. Once the opening is above a certain size they will also rod the the bed joints for additional strength. Re: New home build - Custom Design WA 36Mar 22, 2019 11:37 pm Not doubting what you are saying but I'd be interested to know what code it violates. Was it a double storey build. In 30 years in the building industry I've never seen single course bricking over internal steel frames for single storey residential construction. If that's the case then just about every single house built since the invention of the maxi brick wouldn't comply. Accessible Carpentry & Cabinets accessiblecarpentry@gmail.com accessiblecarpentry.com.au https://www.facebook.com/pages/Accessible-Carpentry-Cabinets/583314911709039 Re: New home build - Custom Design WA 37Mar 25, 2019 10:21 pm chippy Not doubting what you are saying but I'd be interested to know what code it violates. Was it a double storey build. In 30 years in the building industry I've never seen single course bricking over internal steel frames for single storey residential construction. If that's the case then just about every single house built since the invention of the maxi brick wouldn't comply. Re: New home build - Custom Design WA 40Mar 27, 2019 8:36 pm What style of windows have you got in your upstairs overlooking the courtyard if I may ask? ideal house depends on the site and location as much as internal floor plan....what is the distance from the house to all four boundaries, where is north, describe your… 3 15165 6 55346 So it looks like we finally have some movement on site! Definitely later than expected, but I'll take any progress at this point. I'll drop by over the weekend to get… 5 27716 |
