Browse Forums Building A New House 1 Jan 27, 2019 10:44 am Hi All, I have a question regarding the height of the slab. When I compare to my neighbors slab I see that my slab height is smaller against theirs. Does it mean the builder has compromised in slab or is it normal? I have even checked other slabs in the street and they look higher too. Your inputs would e highly appreciated. Thanks Re: Height of the slab 2Jan 27, 2019 10:57 am mrcool4 Hi All, I have a question regarding the height of the slab. When I compare to my neighbors slab I see that my slab height is smaller against theirs. Does it mean the builder has compromised in slab or is it normal? I have even checked other slabs in the street and they look higher too. Your inputs would e highly appreciated. Thanks Depends on the slab type and your ground level. On a flat land a typical raft slab will be lower than a waffle slab. But a raft slab is better than a waffle slab. If both are waffle slab the higher waffle slab normally is stronger. Sometimes client could ask their waffle slab to be higher by choice. Re: Height of the slab 3Jan 27, 2019 11:03 am MyFirst mrcool4 Hi All, I have a question regarding the height of the slab. When I compare to my neighbors slab I see that my slab height is smaller against theirs. Does it mean the builder has compromised in slab or is it normal? I have even checked other slabs in the street and they look higher too. Your inputs would e highly appreciated. Thanks Depends on the slab type and your ground level. On a flat land a typical raft slab will be lower than a waffle slab. But a raft slab is better than a waffle slab. If both are waffle slab the higher waffle slab normally is stronger. Sometimes client could ask their waffle slab to be higher by choice. Thanks Mate. I think mine is waffle slab, so does it mean like I have higher chances of movement? Re: Height of the slab 4Jan 27, 2019 11:07 am mrcool4 MyFirst mrcool4 Hi All, I have a question regarding the height of the slab. When I compare to my neighbors slab I see that my slab height is smaller against theirs. Does it mean the builder has compromised in slab or is it normal? I have even checked other slabs in the street and they look higher too. Your inputs would e highly appreciated. Thanks On a flat land a typical raft slab will be lower than a waffle slab. But a raft slab is better than a waffle slab. If both are waffle slab the higher waffle slab normally is stronger. Sometimes client could ask their waffle slab to be higher by choice. Thanks Mate. I think mine is waffle slab, so does it mean like I have higher chances of movement? I would think the builder's engineer would design a slab suitable for your land. Depends on your soil classification and if there is any fill etc etc. Check your slab engineering details and your soil classification. Re: Height of the slab 5Jan 27, 2019 11:01 pm Just make sure you have good site drainage away from the slab, as best as you can anyway. You might have better soil ie possibly you don't need as thick a slab. Otherwise you can get your engineering explained to you by the engineer or get it peer reviewed by an independent engineer. Or have faith it's all ok. Re: Height of the slab 6Jan 28, 2019 6:58 am sweetswisssteel Just make sure you have good site drainage away from the slab, as best as you can anyway. You might have better soil ie possibly you don't need as thick a slab. Otherwise you can get your engineering explained to you by the engineer or get it peer reviewed by an independent engineer. Or have faith it's all ok. Thanks Mate Unless the room is for storage then it's non compliant BCA V2 2019 S3 P3.8 You have 2 options 1. The builder deconstructs the section and rebuilds as per plan /… 7 10684 ok thanks - yes was wondering if that should have been listed as Option Three! 2 7742 I'll look into different shower heads and ask the plumber about some engineering and see what he says. Thanks 2 9563 |
