I know we need to pass a BASIX test, and I know things included in your build contribute to that pass?
I'm guessing that eaves and water tanks are the two biggies but what else and how much weight do they carry.
Browse Forums Building A New House Re: BASIX for dummies 2Sep 13, 2008 4:14 pm Hi happyhome, be aware that upstairs ducted airconditioning ( if you're going dbl storey) is not permitted. So you won't be permitted to install upstairs vents or ducting.
Downstairs is fine, though. We will do it after handover. If you like I can scan & email our BASIX report to your private email address. If you're interested, just send it to me via PM. If you're not installing ducted AC, then it doesn't matter. Built the Eden Brae Cambridge 34 Family with Boston Corner Facade Re: BASIX for dummies 4Sep 13, 2008 6:53 pm We've got ducted aircon upstairs as well - we just had to chuck in a few more yucky dedicated energy saving lights - the gas HW also helped gain a few points too I think. Built a Clarendon 'Balmain' 2008 Re: BASIX for dummies 5Sep 13, 2008 6:58 pm Just log onto the Basix website and try various options. It only takes about an hour to do (one you have all your window sizes). It's very educational. I did my own Basix and this is the way it is meant to be. Demolition August 2009, Construction Started September 2009, Completed December 2010 Re: BASIX for dummies 6Sep 13, 2008 7:06 pm We are another with ducted aircon upstairs. We have huge water tanks, eaves, a couple of whirly birds in the roof, sarking, indoor and outdoor clothesline, dedicated areas that have to have energy efficient globes (bathroom, laundry, study I think), and gas h/w.
Bel Still not in. Don't ask!? Re: BASIX for dummies 8Sep 13, 2008 7:56 pm Southies and I are using the same builder, she might be referring to their allowances, or in this case no allowances!
Thanks for the info, we will have sarking, eaves, water tank, gas not available in our suburb, and a light colorbond roof (would that count?) I did see the website but didn't have all our details to make it an accurate assessment. Re: BASIX for dummies 14Sep 13, 2008 8:59 pm Judie We're installing ducted air conditioning upstairs, so I don't think it's not allowed at all. You have to compensate for it in different ways. Judie Well, it seems as though our builder didn't do a good job compensatin in other ways, otherwise we would have gotten the go-ahead for the AC. No matter, we've been told that we can do it after final council inspection. Built the Eden Brae Cambridge 34 Family with Boston Corner Facade Re: BASIX for dummies 15Sep 13, 2008 9:03 pm bel Southies, our brick is classed as 'medium Solar Absorptancy 0.475- 0.7' which is a choc brown brick, and roof tile is SA dark (Charcoal). Don't know what our bricks are classed, but they are a choc brown also & our colourbond roof will be jasper. At this point, it's not an issue for us. We're past that point now. We'll just go ahead & do what we want in the end, regardless of what the Basix report stipulates. Built the Eden Brae Cambridge 34 Family with Boston Corner Facade Re: BASIX for dummies 16Sep 14, 2008 10:03 am Hi Southies. That's fine, you can do whatever you want, but if you do something contrary to the BASIX stipulations before the final occupancy cert, they won't give you one until you comply.
So, you have two choices. Do everything exactly as in your current BASIX cert and then make changes after you get th occupancy cert or Do a new BASIX cert and change a couple things if you can get a different result. Greg Re: BASIX for dummies 17Sep 14, 2008 2:40 pm gpierce So, you have two choices. Do everything exactly as in your current BASIX cert and then make changes after you get th occupancy cert or Do a new BASIX cert and change a couple things if you can get a different result. Greg The 1st option is the way we'll go. We're quite happy to have the AC done after the Occ Cert for obvious reasons. Actually, we've also been advised by the builder to go that way. Built the Eden Brae Cambridge 34 Family with Boston Corner Facade |
