Browse Forums Building A New House 1 Sep 13, 2008 9:35 am Hi all,
I thought it was time that I shared some images of our project. We bought land in June 07 in the Watervale estate in Taylors Hill (NW Melbourne). Here is a pic of our block which is at the end of a court (taken in June 07) there is only our block and a couple others which have not yet started to build. The block is a good size at 853 sqm and rectangular with a very slight fall. http://i497.photobucket.com/albums/rr338/ascollins71/Pictures171007005.jpg We had initially gone down the path of getting the house custom designed however this proved to be outside of our budget and we have now settled on the Stanthorpe 33 by Dennis Family Homes. Here is a pic of the floorplan. http://i497.photobucket.com/albums/rr338/ascollins71/Stanthorpe330Floorplan.jpg The only change which we are planning to make structurally is to replace the living room with an outside room (alfresco). Currently we are working towards getting a quotation for the house as we would like to incorporate a lot of our fitting / finishes selections which we made when designing our custom house. Will keep you posted Regards NoviceBuilder Re: Our House 6Sep 13, 2008 11:51 pm Hi all,
That was the one thing that we liked about the Stanthorpe as it was similar to the original plan we designed we wanted a lot of storage space within the home. We have been through a lot of the display homes and generally storage space is at a minimum. We were working on the basis that you can never have enough storage space hence one of the reasons for settling on this design. In terms of the block we are at the end of a hammer head court so in order to best use the block we were wanting the house to run along the block as opposed to the standard configuration of the house at the front of the block and using the depth of the block. Regards NoviceBuilder Re: Our House 7Sep 27, 2008 12:00 am I thought it was time for an update on the progress.
We have redesigned part of the floorplan so that it will comply with the requirements of the developer's setbacks and have also paid an initial deposit. We are about to start our research for colours as we are currently waiting for DFH to conduct a soil test and to prepare the contract. I will keep you posted. Regards, NoviceBuilder Re: Our House 8Sep 27, 2008 9:10 am I have included a copy of the revised floorplan below.
Would appreciate any feedback on the revision http://i497.photobucket.com/albums/rr338/ascollins71/RevisedStanthorpe33Floorplan.jpg Regards, NoviceBuilder Re: Our House 9Sep 27, 2008 10:27 am Hi Novice Builder, I like your plan and especially the alfresco in the middle. I suppose what I would consider.
1. Do you have littlies and will the noise from the alfresco effect the minor rooms and also the entrance into the house from the garage for the same reason? 2. I would also consider your family room doesn't have any walls for a sofa to or Tv to sit against. Or will you be floating the sofa in the middle of the room? I think otherwise a good plan, i look forward to seeing your house come along....good luck. Re: Our House 11Sep 27, 2008 11:47 am gweluphome Hi Novice Builder, I like your plan and especially the alfresco in the middle. I suppose what I would consider. 1. Do you have littlies and will the noise from the alfresco effect the minor rooms and also the entrance into the house from the garage for the same reason? 2. I would also consider your family room doesn't have any walls for a sofa to or Tv to sit against. Or will you be floating the sofa in the middle of the room? I think otherwise a good plan, i look forward to seeing your house come along....good luck. Hi Gweluphome, Thanks for your feedback 1. We have one on the way and we are considering putting a door from the entry to close off that part of the house and to reduce noise. 2. Yes I think the sofa and TV will just float in the middle of the family area. We are planning on using the Games room as a dedicated home theatre. Thanks NoviceBuilder Re: Our House 12Sep 27, 2008 11:58 am kristofw Which way is North ? Have you tried to implement some elements of passive design ? Chris Hi Chris, North is at the top of the floor plan so that all living areas are facing north and the bedrooms are on the south side. Could you clarify what you mean by passive design? Thanks NoviceBuilder Re: Our House 13Sep 27, 2008 12:23 pm Another thought NB, With one on the way. We did it in our last house.....like your plan we had a study coming off our master bedroom, we added a door so that we could also enter the study via our bedroom and we also added a robe so that way once bub came along I was able to put him into that room as a nursery. Very handy as we never needed him to stay in our room yet he was close by for feedings and etc in the middle of the night. I can't tell you how good this was as a decision.
This also could make your house classed as a 5 bed fro resale. Then when he was old enough to go into a big room and it would convert back to a study. We also put wood floors in there so in the middle of the night any accidents were an easy wipe up and not down on new carpet. This is also good once its a study for an office chair to roll well. I know its not for everyone but it actually was a good selling point when we sold that house aswell. Re: Our House 14Sep 27, 2008 5:00 pm Quote: North is at the top of the floor plan so that all living areas are facing north and the bedrooms are on the south side. Could you clarify what you mean by passive design? Good on you NB, the first element of passive design - orientation - is there. As for the other two
Chris My father rode a camel, I drive a car, my son flies in a jetliner, his son will ride a camel.Saudi saying Re: Our House 15Sep 27, 2008 5:08 pm I love that design, more the original though.
I think the alfresco is a really unusual shape that would have a lot of wasted space. I'd be more inclined to put a square alfresco extended straight from the meals area. Re: Our House 16Sep 27, 2008 6:06 pm kristofw Quote: North is at the top of the floor plan so that all living areas are facing north and the bedrooms are on the south side. Could you clarify what you mean by passive design? Good on you NB, the first element of passive design - orientation - is there. As for the other two
Chris Hi Chris, What type of insulation should be on the outside? The house is going to be built on a slab so there will be a thermal mass. Floor coverings will be either carpet, floorboards or tiles. As far as the windows are concerned they will be good quality (A & L Windows) however I think they are single glazed. The facade we have chosen does have eaves on the North side of the house. Regards, NoviceBuilder Re: Our House 17Sep 27, 2008 6:19 pm Quote: What type of insulation should be on the outside? Chris My father rode a camel, I drive a car, my son flies in a jetliner, his son will ride a camel.Saudi saying Re: Our House 18May 27, 2009 8:27 am Hi all It has been a while since I have updated you on the progress of the house. We have a site start date of the 3rd March 2009 and are currently about a week away from lock up stage. I have set up a blog which will have pictures of the slab and frame and I need to add more photos now that the bricks are up. Regards NoviceBuilder NoviceBuilders House - http://novicebuildershouse.blogspot.com/ Building a modified Stanthorpe 33 in Taylors Hill Vic Re: Our House 19May 27, 2009 5:09 pm Gosh it's really taking shape, how exciting. I love the floor plan it's great. I can't wait to see what colours you've selected for everything. The kitchen is going to look amazing with that design. I hope everything is going smoothly with the build so far. Re: Our House 20May 27, 2009 6:51 pm Regarding the solar orientation, I'm not sure there are enough significant windows along the north to qualify? Do you have double-glazing, at least on the southern side? I love the plan. You've included an excellent amount of storage. I had a look at your blog, your walk-in linen and walk-in pantry are fantastic. And more storage up the other end too! It's just going to get even more exciting as the details of the interior take shape. of course there are legal avenues. You've already mentioned it. Sue them. I find it odd that lawyers wouldnt be willing to take on the case, given CCT evidence and… 1 23785 "Losers" "humanity" "off time" "your" "top notch" "love symbol" Sounds like ponzo is done using other people's toilets 36 23918 |
