Browse Forums Building A New House Re: Does ceiling height adds value to the property? 2Dec 25, 2018 7:46 pm Short answer is yes, absolutely. Do it, you won't regret the decision. It makes the home look that much bigger and spacious, instead of cramped. I would also suggest making the doors 2050 high in lieu of standard. Building a Madison 45 with Porter Davis Madison 45 Blog (Send me a PM with your email address to be added) Re: Does ceiling height adds value to the property? 3Dec 25, 2018 8:22 pm Walk through a few display homes, you can tell the difference between standard height and 9 foot. If budget is tight then you may need to reconsider but I’d do that over many other ‘upgrades’ Re: Does ceiling height adds value to the property? 4Dec 25, 2018 8:38 pm If the cost is too much for 2.7m then 2.59 is a better option than 2.4m standard height. Re: Does ceiling height adds value to the property? 5Dec 26, 2018 7:18 am Ceiling height is something to do before other things like kitchen bench tops and fancy taps You cannot modify ceiling heights as you can do the former after the build. So see what you can afford in ceiling height and go with it. When I was looking at displays the one thing I was impressed was the metricon Bordeaux and it's 3m dowstairs ceilings. It gave the house an airness that I had not seen before as most other displays had 2.7m ceilings. It was that reason that years later when time come to build a 3m ceiling was the first on my checklist. Re: Does ceiling height adds value to the property? 6Dec 26, 2018 10:34 am All better end homes will have higher ceilings, it can be one of those things that stop some people buying your home when selling, especially if your use to a more spacious look and feel, worth every cent, go for highest you can. Re: Does ceiling height adds value to the property? 9Dec 28, 2018 9:05 am Absolutely higher ceiling!!! We have ground floor ceiling height to 2740mm and upstair ceiling height to 2590mm. All ground floor room doors are 2340mm high even kitchen pantry doors. Our friends are loving higher ceiling of our house and they wish they have high ceiling like us....feels very spacious. Re: Does ceiling height adds value to the property? 10Dec 28, 2018 12:26 pm Hi shazaw, did you leave your door heights in the upper floor as standard? Thanks Re: Does ceiling height adds value to the property? 11Dec 28, 2018 7:49 pm We've gone for 34 course (2914mm) in our portico, entry, front hallway, kitchen, dining, living and alfresco. The remainder we've done 31 course (2657mm), and a 34 course recessed ceiling in the theatre. We saw a display will taller ceilings like this and it looked fantastic. The cost is worth it for resale (well I think so anyway). Re: Does ceiling height adds value to the property? 13Jan 11, 2019 8:09 pm We end up paying extra $850 for 2340mm high pannelled 10 doors, extra again for 2 * 2340mm high cavity sliding $613... please note these prices were from 2014. Everything do add up little by little BUT looking back now I wished I have added more major items like soundproof insulation between subfloor especially above guest bedroom. Build Thread : viewtopic.php?=31&t=81624 Re: Does ceiling height adds value to the property? 14Jan 11, 2019 10:33 pm shazaw Melbournevic Hi shazaw, did you leave your door heights in the upper floor as standard? Thanks Sorry for late reply, Yes upper floor doors are standard heights. No probs, thanks shazaw. We are having standard door heights as well to upper floor and I was just curious to know. They make the room much easier to clean for one, reflect more light (if light colour tiles are used), and you dont end up with dust on the top edge of tiles (cause most… 3 9594 Unless the room is for storage then it's non compliant BCA V2 2019 S3 P3.8 You have 2 options 1. The builder deconstructs the section and rebuilds as per plan /… 7 10683 As a tradesmen get a private inspector although I don't think there worth it in their profession themselves the reminder they serve to the tradesmen doing the work is… 3 27360 |
