Browse Forums Building A New House 1 Dec 22, 2018 7:54 pm Hi guys, My builder is charging me $524 to install the TV antenna, should I get it done now or get the electrician to do it later when I will get the down lights installed? Also, he is charging me $4,700 for evaporative cooling, $750 for garage remotes and $3,500 for driveway. Can someone please suggest if I can save some money by getting it done later. I am building a single store house in Melbourne West. Thank you Re: Should I get the TV antenna installed? 2Dec 23, 2018 7:09 am Frank1234 Hi guys, My builder is charging me $524 to install the TV antenna, should I get it done now or get the electrician to do it later when I will get the down lights installed? Also, he is charging me $4,700 for evaporative cooling, $750 for garage remotes and $3,500 for driveway. Can someone please suggest if I can save some money by getting it done later. I am building a single store house in Melbourne West. Thank you I recently built in Sydney and my builder charged $600 for antenna installation which I thought was pricey so didn’t get it done. Since I moved in, I got various quotes from Jim’s and Mr Antenna and they range from about $400-$550 so all cheaper than what the builder was charging. DIY, Home Maintenance & Repair Brilliant - thanks so much for that. I didn't want to start pulling too hard on it if there was some other way it was attached, but yep, it was just the paint sticking it… 2 3174 The unit normally clips into a metal plate screwed to the wall, either plate is not flush, or unit not hooked in and could be hanging from the pipes partly, either might… 2 15798 Depends how much direct sun it gets. Is there any shading (eaves or trees)? If the sun hits a window directly it doesn't matter too much if it's double or single… 1 12671 |
