Browse Forums Building A New House 1 Dec 12, 2018 7:59 am Cooling question: We are looking at a 2 story house in and I like the idea of either all evap cooling or a combo of evap and split systems. Can I ask what other people have done and also an idea of cost? - I know there is variation based on the house/builder but a rough idea is always helpful. I’ve also been mulling over what we do during the build vs what we do post handover (obviously if we do evap downstairs then we will have to do it in the build). This is due to initial cost but also wanting to consider what will be cheaper to run long term and more effective. We are building near the sea so will have some sea breezes. Bonus points if you’ve built a reverse living home! Re: Cooling (2 level evap and/or split system decision) 2Dec 12, 2018 10:05 am RobGee Cooling question: We are looking at a 2 story house in and I like the idea of either all evap cooling or a combo of evap and split systems. Can I ask what other people have done and also an idea of cost? - I know there is variation based on the house/builder but a rough idea is always helpful. I’ve also been mulling over what we do during the build vs what we do post handover (obviously if we do evap downstairs then we will have to do it in the build). This is due to initial cost but also wanting to consider what will be cheaper to run long term and more effective. We are building near the sea so will have some sea breezes. Bonus points if you’ve built a reverse living home! I’m assuming you’re building an upside down house going by your last line? We’re about to commence construction on a reverse living design that’s taken a long time to get it to the point where we’re ready to start building. Anyway we’ve had the exact same thoughts on splits/central/evap. etc. you’re having. The evap. cooling decision was taken away from us as we’re having a flat roof, so not practical to get the ducting in. If it were a normal roof we’d have got it along with splits. In a reverse living design you’d only need the outlets upstairs as the colder air should drop down via the stairs to the lower levels, especially if you have some windows downstairs open (have an outlet above the stairs also). We’ve decided on 2 splits upstairs (living and master) and 1 split in downstairs living area. The lower bedrooms will have ceiling fans and are sited to minimise any solar gain. Move your linen into laundry and access laundry from your present linen space 1 5743 isn't a garage level with the rest of the house a given? pretty sure they 'came around' long time ago. if you have a flat block, the garage is usually level with the rest… 1 13364 they can, it's a fairly standard solution when the slab isn't recessed. the falls need to be in the main floor, if it hasn't been done then you need to ask them to redo… 4 5053 |
