Browse Forums Building A New House 1 Dec 06, 2018 4:45 pm Hello Guys, I have a question about weeping holes on a near completion house. I noticed in the pre-handover inspection that there is no weeping hole on the bricks under all the windows and doors. But I could them on all the neighbour who builds with the same builder as us. Just wondering if this is something I should worry about and push our builder to fix before handover? Here is some pics at front as example but we got this issue all over our house, here is us Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Our neighbour (With weeping holes). Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Weep holes on the bricks under the window missing 2Dec 06, 2018 4:55 pm Any help would be much appreciated it depends on the natural ground level, if they excavated their boundary wall needed to be built as a retaining wall. If you filled, which sounds like the case then you… 1 7063 I know foam has been around since the 90's and CSR started manufacturing Hebel in 1989, so it's definitely possible 5 5404 You are correct. Just read through all the ncc rules and 75mm is the minimum requirement for me. 4 11111 |
