Browse Forums Building A New House 1 Nov 24, 2018 2:20 pm deleted M Y C U S T O M C O R A L B R O N T E 43 ...............Kitchen! 16 Nov 2016 https://forum.homeone.com.au/viewtopic.php?f=31&t=79581 Re: Steel joists issue and builder won’t give info 3Nov 25, 2018 8:14 am The ceiling will need to be removed and the trusses stiffened BTW, This could have been picked up if the trusses were properly inspected/tested by your engineer during the frame inspection stage. Check the builders engineering drawings..no doubt it will say engineered Floor trusses by others? and since the builder doesn't pay his Engineer to inspected the trusses and nor did you.. Caveat Emptor Personally I would have been very unhappy if those trusses were installed in my house do you have other photos of the trusses. Good luck Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Steel joists issue and builder won’t give info 4Nov 25, 2018 11:38 am . M Y C U S T O M C O R A L B R O N T E 43 ...............Kitchen! 16 Nov 2016 https://forum.homeone.com.au/viewtopic.php?f=31&t=79581 Re: Steel joists issue and builder won’t give info 5Nov 25, 2018 12:06 pm . M Y C U S T O M C O R A L B R O N T E 43 ...............Kitchen! 16 Nov 2016 https://forum.homeone.com.au/viewtopic.php?f=31&t=79581 Re: Steel joists issue and builder won’t give info 6Nov 25, 2018 12:14 pm . M Y C U S T O M C O R A L B R O N T E 43 ...............Kitchen! 16 Nov 2016 https://forum.homeone.com.au/viewtopic.php?f=31&t=79581 Re: Steel joists issue and builder won’t give info 7Nov 25, 2018 1:55 pm MrsJM Happy to insist if I am able, here's some pointers 1. All houses take 6-12 months to settle (season/year cycle), loads are redistributed, Unfortunately, that generally takes you outside of the maintenance period if problems persist or get worse 2..Placing extra screws into the truss nodes doesn't stiffen the trusses, but it does highlight a potential problem with them 3.I suggest you start with a copy of the certified structural Engineering Drawings, If the builders hasn't given it to you , check with your local Council building Department..ask for a copy... hth Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Steel joists issue and builder won’t give info 8Nov 25, 2018 3:57 pm . M Y C U S T O M C O R A L B R O N T E 43 ...............Kitchen! 16 Nov 2016 https://forum.homeone.com.au/viewtopic.php?f=31&t=79581 Re: Steel joists issue and builder won’t give info 9Nov 26, 2018 7:23 am How do you know that the person who designed the floor joists has engineering qualifications? Engineering drawings are signed by an engineer.Please check with your Councils Building department for a signed copy Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Steel joists issue and builder won’t give info 10Nov 27, 2018 3:31 am . M Y C U S T O M C O R A L B R O N T E 43 ...............Kitchen! 16 Nov 2016 https://forum.homeone.com.au/viewtopic.php?f=31&t=79581 |
