Browse Forums Building A New House Re: Peg out. What does this mean and is it correct? 2Nov 17, 2018 1:54 pm Your house is obviously smaller than the block of land , so it must be located with appropriate offsets from the boundaries. This is marked with pegs. Unless you are experienced you will not understand it and also there may be additional complications from true lines being offset because of obstructions. Foremost Building Expert in Australia,assisting with building problems/disputes, building stage inspections,pre-contract review advice for peace of mind 200 blogs http://www.buildingexpert.net.au/blog 4 14300 Unless there is something in special conditions the builder does not have to give you timeline. If your demolition contractor has not removed Asbestos and it was found… 12 28809 Thanks for the informative response! I'll feed that back to the site supervisor. 2 4126 |
