Browse Forums Building A New House Disappointment with Clarendon Home and Austral Brick 3Nov 15, 2018 3:03 pm By the way, moisture ingress can be tested. Has anyone applied a moisture meter to the different bricks and shown you the results? https://www.instrumentchoice.com.au/emails/Monthly%20Newsletter/10-4-16/choosing-the-best-moisture-meter-for-building-applications Re: Disappointment with Clarendon Home and Austral Brick 4Nov 15, 2018 3:25 pm Yes Austral sales rep said they did a moisture check but didn't give us a report on the day. Our inspector did a test that day and the difference between the top and the bottom was around 10%. Clarendon Area Manager said from his memory the brick seems lighter since he last visit on our site 2 weeks ago. We have taken many pictures to show them but, they didn't seem to care. All they said was moisture and there's nothing it can do done, even if we were going to give him a report from our inspector. They didn't even ask us what we wanted as an outcome of our complaint. Re: Disappointment with Clarendon Home and Austral Brick 5Nov 15, 2018 6:16 pm leslie cheong They didn't even ask us what we wanted as an outcome of our complaint. Would you have had an answer if they had? This is something you should be proactive about. The biggest issue with dispute resolution is to come to a conclusion, so it often just leads to ongoing bitterness without an outcome. Figure out what it is you want and tell them this as part of the complaint. But be reasonable, as no one can deliver the impossible. Re: Disappointment with Clarendon Home and Austral Brick 6Nov 27, 2018 1:58 pm leslie cheong Yes Austral sales rep said they did a moisture check but didn't give us a report on the day. Our inspector did a test that day and the difference between the top and the bottom was around 10%. Clarendon Area Manager said from his memory the brick seems lighter since he last visit on our site 2 weeks ago. We have taken many pictures to show them but, they didn't seem to care. All they said was moisture and there's nothing it can do done, even if we were going to give him a report from our inspector. They didn't even ask us what we wanted as an outcome of our complaint. my 2cents There is a solution which is to colour/dye the bricks ( the product is called Nawkaw), but its extremely expensive. if they have laid the wrong bricks you are well withing your rights to demand that they either, relay them, render the house or dye the bricks Simeon McGovern Affordable Custom Homes, We design and build to your budget Ashington Homes www.ashingtonhomes.com.au Re: Disappointment with Clarendon Home and Austral Brick 7Nov 27, 2018 1:59 pm Simeon McGovern Affordable Custom Homes, We design and build to your budget Ashington Homes www.ashingtonhomes.com.au Re: Disappointment with Clarendon Home and Austral Brick 8Apr 09, 2019 3:18 pm This happened to me on a previous build. Mine was moisture to which evaporated. But, the colour didn't return either. I just ended up having to live with it. Its the same with yours. You can see the weep holes are located directly above where the moisture is. The moisture barrier usually sits just below this, however I am not sure why it is so high. Did you build you block up (ie: due to slope or flooding?) Follow Our Clarendon - Double Gable, Hamptons Inspired Fairmont 35 https://forum.homeone.com.au/viewtopic.php?f=31&t=94604 Anyone built with Fowler Homes? Feedback? Especially any things concerning or negatives? Have heard some horror… 0 9309 The two 15mm holes are obviously not compliant. The Dept of Fair Trading would love to see this one! Do the gutters pool water after it stops raining? Although it's… 4 7863 the stair balustrades? There is nothing special about these and I imagine literally every stair installer will be able to do this. 1 6738 |
