Browse Forums Building A New House 1 Nov 12, 2018 6:02 pm Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ There is a step down in garage slab. The framing stands on the stepped down slab on two sides. One side it is flush to the slab edge. However, the in the second side there is a gap of around 40mm between slab and frame base, as it appears in the photo. I guess, the framer has done this deliberately to get the room size correct. If it is flush, the room next to garage (pantry and powder room in this case) would get reduced by around 40mm. I asked the framer about this gap. He told that the gap later will get filled up by some concrete or something. Has anybody come accross a similar situation? Is it a concern? would they really fill? thanks. Start a topic... Re: Framing - Gap Between Slab Edge and Frame 2Nov 13, 2018 11:31 am When we built our last house, we had a step down to the garage as well. The slab was slightly out which ended up the same as yours. That was 20 years ago and we had no problems at all with the house at all and you wouldn't have even known. Ours was never filled. Re: Framing - Gap Between Slab Edge and Frame 4Nov 13, 2018 1:00 pm ![]() Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ There is a step down in garage slab. The framing stands on the stepped down slab on two sides. One side it is flush to the slab edge. However, the in the second side there is a gap of around 40mm between slab and frame base, as it appears in the photo. I guess, the framer has done this deliberately to get the room size correct. If it is flush, the room next to garage (pantry and powder room in this case) would get reduced by around 40mm. I asked the framer about this gap. He told that the gap later will get filled up by some concrete or something. Has anybody come accross a similar situation? Is it a concern? would they really fill? thanks. Start a topic... Mine is exactly like yours. Currently under construction. I worry about lots of things.. However this issue doesn't bother me at all. The frame is sitting firmly on the garage slab hence I have no concern. The gap will be "filled" by the plasterboard and skirting board. Re: Framing - Gap Between Slab Edge and Frame 5Nov 14, 2018 8:36 am We have no gap, and the slab lines up perfectly. But our slab guys were meticulous with their measurements, as they had a couple of boxes of beer riding on it... That being said, it's nothing to worry about if it's not a load bearing wall Our Bayside KDR Thread: viewtopic.php?f=31&t=78298 Are you in Melbourne if yes contact burrat engineering he good at what he does he is a civil and structural engineer. Give him a ring , his name is Steve Buratt. Thats… 6 2750 The stone isn't cracked, the supporting structure has moved. Nothing to serious, scrape it out and clean with thinners, run some new sealant into it, spray with soapy… 4 1430 Hi everyone Looking for some advice. My frame does not sit on the slab at the edge all the way around. At some parts the slab is protruding a maximum of 40mm. We… 0 2989 |
