Browse Forums Building A New House 1 Oct 16, 2018 11:01 pm Hi all, I am new to this forum and am getting close to signing a contract with a builder. One thing that they have not been able to explain adequately is the difference between a dropped edge beam and a 'standard' brick rebate. Initially site costs included for dropped edge beams with up to 5 brick courses. When I queried the cost and necessity of this (as my land has a maximum of 500mm fall across the block and about 200-300mm across the building envelope) this was removed from the contract which means I will now get the standard offering of a brick rebate. I have asked for an explanation of what this actually means in lay terms but have not been able to get an answer. They have simply said that I will get a better idea of how this looks once the plans are drawn. I would like to understand this before I sign and commit to a 5% deposit. I was hoping someone here may be able to explain this for me? Re: Dropped edge beam versus brick rebate 3Oct 17, 2018 7:53 am Bailey Welcome to the forum, More information is required ie, contour survey, site geotech report as there are various slab construction/engineering alternatives in AS2870 Residential Slab & Footings Forewarned is Forearmed Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Dropped edge beam versus brick rebate 4Oct 17, 2018 6:42 pm @ StructuralBIMGuy thanks for the reply. I have attached the contours and details re site inclusions. There is no Geotech report yet as the land does not register until mid next year. I am building in the Maitland NSW area and have been advised by a variety of sources that this is a salinity affected area and a H1 or H2 class slab will most likely be required. I have found info on dropped edge beams, including the link that alexp79 provided but haven't really found anything on the brick rebate which is now being offered. Not really sure what the brick rebate is or what it will look like, when it can or cannot be used and what the drawbacks may be. Just wanting to learn more about it so I am prepared. If it turns out that a dropped edge beam is the better option I want to make sure I have budgeted for it. If I am honest I am somewhat alarmed that when I queried the builder on site costs they removed all the additional requirements (clause 4-4) and reduced costs but when I said this concerned me as my understanding is that I will need the upgraded slab and salinity affected area requirements they put those back in at no charge. The only thing left off is the dropped edge beam so I am trying to do some due diligence to make sure I understand what I am getting. My contract is a house and land package so any shortfall in site inclusions will be at their cost. However I would assume that brick rebate vs dropped edge beam is a personal preference and will only affect the aesthetic appearance? Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Dropped edge beam versus brick rebate 5Oct 19, 2018 9:22 am Hi Bailey86 Best to wait for the geotech report, if it gets classified P you may well require piles In The meantime 1.Check with owners that are building with your builder in the adjoining stages 2.The market is Still Hot 3.Build Prices will Stabilising and eventually drop (as seen in Perth), make sure you are getting long term value for money 4.Be prepared for delays, there is no need to rush post back with geo report & floorplan HTH Cheers Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Hello everyone, After some suggestions and ideas about how to put a concrete path around the drop edge beam area on our new build. We are required to have a concrete path… 0 12888 The distance between my DEBs varies from 4.1m at the narrowest to 8.1m at the widest. 5 27337 |
