Browse Forums Building A New House Re: Double brick - Internal wall finish 3Oct 31, 2018 6:46 am Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Double brick - Internal wall finish 4Nov 03, 2018 6:50 pm Sethor Just google Plaster vs Drywall, But basically plaster is better. It does have some disadvantages, we opted for drywall in the staircase as plaster will form cracks where brickwork & suspended slab meet. Re: Double brick - Internal wall finish 5Nov 03, 2018 11:34 pm Andree Some builders in Perth are still using cement render with a plaster finish which is what i'm familiar with and and some are using a 12mm gyprock board. any pros and cons either way? We went with drywall, pros would be house went up faster as drywall was done in a day, smoother finish so when the other half painted he didn’t have to fill in or patch anything and we could seal our walls early our builder let us seal them before lock up, I would say only down fall is our cats a climber and I kid you not we have scratches on our walls from her climbing 😡 but I would still stick with the drywall if we built again 🤷♀️ Re: Double brick - Internal wall finish 7Nov 06, 2018 1:16 pm Doozer1905 Sethor Just google Plaster vs Drywall, But basically plaster is better. It does have some disadvantages, we opted for drywall in the staircase as plaster will form cracks where brickwork & suspended slab meet. No way, plaster is not even close to Drywall. Drywall is a premium product with a premium finish, why do you think all the high end builders use Drywall. Which high end builders? Only cheaper builders are pushing drywall as it is cheaper & faster. Re: Double brick - Internal wall finish 8Nov 06, 2018 1:23 pm StructuralBIMGuy You shouldn't have any structural cracking in un-reinforced brickwork? What would you rather do see the cracks and fix them, or mask them completely and not know how dangerous the problem is? We just did not want to deal with the hairline cracks you get with settling, just seen to many houses hairline cracks in plasterwork in staircases. Re: Double brick - Internal wall finish 9Nov 07, 2018 12:18 am Sethor Doozer1905 Sethor Just google Plaster vs Drywall, But basically plaster is better. It does have some disadvantages, we opted for drywall in the staircase as plaster will form cracks where brickwork & suspended slab meet. No way, plaster is not even close to Drywall. Drywall is a premium product with a premium finish, why do you think all the high end builders use Drywall. Which high end builders? Only cheaper builders are pushing drywall as it is cheaper & faster. Re: Double brick - Internal wall finish 11Nov 07, 2018 7:14 am Easier to repair if damaged? How do you repair the unreinforced brick work if you can't see the damage? Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Double brick - Internal wall finish 12Nov 08, 2018 2:50 pm Doozer1905 Sorry Sethor you have no idea what your talking about. None of the cheap builders Drywall and if you asked them what's the cost to Drywall it would be thousands. So builders that Drywall, Summit offer it as an upgrade as well as BGC, JWH group & Dale Alcock all as an upgrade. Webb & Brown, Platinum homes & Zorzi are the builders that I know offer it as a standard. I can tell you first hand Zorzi don't dry wall. There would be heaps of 100+ year old homes in Perth with original plaster walls, do you think drywall is as durable? I doubt anyone offers it as a upgrade, I'm sure most builders would do it as a no cost option as it is cheaper to install. If drywall is better why would most builders continue with an inferior method which is more labour intensive & slower to install? Re: Double brick - Internal wall finish 13Nov 08, 2018 2:53 pm Like I said before Sethor you have no idea what your talking about. Re: Double brick - Internal wall finish 15Nov 08, 2018 5:04 pm No I don't never have, I have worked for 2 of the previous builders mentioned and now work for a boutique builder Re: Double brick - Internal wall finish 16Nov 08, 2018 5:54 pm Andree Some builders in Perth are still using cement render with a plaster finish which is what i'm familiar with and and some are using a 12mm gyprock board. any pros and cons either way? Drywall all the way. Much better finish and not as subject to the mood of the tradie on the day. Our house was plastered and when the sun hits the walls it looks like the plasterer was as well. Swirl marks, ridges, bumps and lumps all over - apparently "all within standard" The one wall that was drywalled looks perfect Re: Double brick - Internal wall finish 17Nov 08, 2018 8:40 pm Good quality plaster is always smoother than drywall (aka gyprock), walls are straight and smooth as a mirror. Not to mention all this "hardness" feeling when you touch or hit it. Thermally drywall behaves a little bit better than gypsum plaster, although overall impact to R of the wall is close to nothing, also there are veneer plasters available out there those days. Acoustically plaster behaves much better as it is heavier and thicker. And at last, but not the least, robotic plastering machines can plaster up to 200 sqm/per hour those days: https://www.youtube.com/watch?v=jLf95eNMYvo&t=9s So it is no longer more labor intensive than gyprock installations. Gyprock is so popular only because it is cheaper and the only available option for framed houses. Re: Double brick - Internal wall finish 19Nov 08, 2018 11:53 pm Althom Good quality yes. Find a plasterer in Perth that delivers it and you'll get some credibility. Not a single wet plasterer in Perth can deliver a good quality plaster? Is it really as bad as it reads? Then surely drywall is the only choice. Oh no, I have forgot that drywalling is also a skilled labour with so many different ways to make things wrong. Alas! Re: Double brick - Internal wall finish 20Nov 09, 2018 9:37 am There would be many, many more competent drywall installers in Perth than there are competent plasterers. It comes down to the likelihood of getting a good job and you're more likely to if you go with drywall Thank you alexp79 and gommeqld for your advice, that's very helpful, thanks 3 7937 3 10201 Sorry, don't know costs, but there are a couple of very important principles you need to get right (and now) .... (1) never agree to any "upgrade" unless you first know… 5 6838 |
