Browse Forums Building A New House Re: Would you share your house budget with a builder 2Oct 13, 2018 9:04 pm Take off like 30% and give them that figure, if they can’t do irk with that then it won’t work, as there’s always upgrades and additions that will happen regardless Re: Would you share your house budget with a builder 3Oct 13, 2018 9:18 pm I told them about 50 to 75k less than i want to spend and he was honest enough to say that'll be close but not enough unless we want very basic finishes. It helps them to know if you're realistic but i wouldn't tell them your maximum budget straight up that's for sure... Re: Would you share your house budget with a builder 4Oct 13, 2018 9:48 pm I was fairly upfront with what my budget was and that it was tight. I had already picked a house design from the builders cheaper range which was a 3 bedroom home. Once I spoke with the sales consultants he actually recommended a different range which was slightly more expensive but was a 4 bedroom house which came with nicer finishes. I questioned him whether the standard inclusions would be enough and he actually took me through the display home and pointed out what was standard and what was an upgrade (some he even knew a rough price). After colour selection, I can say he was pretty correct. The standard inclusions (I did pay for a package that included basic flooring, stone benches, eva cooling, and a few extras for about $5000, well worth it) were actually reasonable and the cost to upgrade most things wasn't too bad. My starting budget was ~$195,000 and I spent ~$205,000. I actually ended up having more wiggle room as my salary increased, hence the over spend on luxuries like double glazed windows, powder room, down lights, upgraded laminate floors, bricks and off white mortar. Fairhaven Homes - Clovelly 191 Re: Would you share your house budget with a builder 5Oct 14, 2018 8:10 am CalicoCat My starting budget was ~$195,000 and I spent ~$205,000. I actually ended up having more wiggle room as my salary increased, hence the over spend on luxuries like double glazed windows, powder room, down lights, upgraded laminate floors, bricks and off white mortar. Wow, what year was that? Re: Would you share your house budget with a builder 6Oct 14, 2018 9:32 am Rami_m It seems like the first thing coming out of a builders mouth when we talk to them is what is your budget. Bit worried they would take me for a ride if I shared actual figures Thoughts? I wouldn't recommend telling them your entire budget. I usually told them about 50k - 75k off my actual budget. It would depend from builder to builder, the standard inclusions they had to offer, the range and the promotion that was going on during that time. Re: Would you share your house budget with a builder 7Oct 14, 2018 2:23 pm arcadelt CalicoCat My starting budget was ~$195,000 and I spent ~$205,000. I actually ended up having more wiggle room as my salary increased, hence the over spend on luxuries like double glazed windows, powder room, down lights, upgraded laminate floors, bricks and off white mortar. Wow, what year was that? I started the process December last year. I'm at lock up stage at the moment. I was lucky my site fees came in pretty cheap (~$6,000). The base price was also reduced by around $5000 due to a promotion. I spoke with a few other builders before settling on Fairhaven Homes and they were all significantly more expensive. Fairhaven Homes - Clovelly 191 Re: Would you share your house budget with a builder 8Oct 15, 2018 9:06 am Rami_m It seems like the first thing coming out of a builders mouth when we talk to them is what is your budget. Bit worried they would take me for a ride if I shared actual figures Thoughts? Rami My 2 cents. I think it is critical that you share your budget so they can design to it. In fairness they don't know if you have $500k or $1.5million so when you are doing a custom build its important to let them know so they don't go overboard with design elements and finishes, other wise you will risk wasting your time and theirs. Also when we were doing ours and it came in $30k over budget, we were able to sit with them and redesign items that werent needed to reduce costs. cheers S Simeon McGovern Affordable Custom Homes, We design and build to your budget Ashington Homes www.ashingtonhomes.com.au Thanks mate. Yeah good points! Leaning towards Option 3 to get a bit extra space in the cabinets but not going too crazy high (and expensive). Would require a mini… 13 39704 traditional gable roof facade - Have you did the dark and light gray color combination in facade with gray stone in facade… 0 4211 Bought in Nov 21 at the height of the market (classic). Good area, atrocious floor plan. BUT has land out to the left-hand side that we can extend out on (see second… 0 8773 |
