Browse Forums Building A New House 1 Oct 10, 2018 1:19 pm Hi, We've just received an initial estimate of costs from our builder and it's left us reeling a bit. Our design is a fairly modest two bedroom, one level home and we've been quoted $27,000 for plastering. Bearing in mind we're using concrete panels, the only plastering will be on partition walls and ceilings (2 bedrooms, utility room, kitchen/dining, living room and two smallish bathrooms) I'm at a loss to see how it could be this much. We've asked for a more detailed breakdown of costs (the quote is $300k above the limit we agreed with our architect/project manager - i.e., almost double!! so we want to look very closely at all estimates/quotes) but, in the meantime, does this seem reasonable? Any rough ideas on what a 'standard' cost might be for plastering partition wall/ceilings (all rooms of modest size, no ornate work)? Re: Cost of plastering 2Oct 11, 2018 8:11 am Dogstar Welcome to the forum Do you have Quantities or a 3D BIM Model & Data Rough Estimate in Perth Skim coat over concrete is $20/m2 + Openings + Extras hth Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs If this is a custom build then I would expect the builder to set out the door frame closer to the wall to avoid the gap between architrave and the wall and or specify… 9 8323 7 12016 We were lucky in that our old house was so small (86 square metres) compared to the new house, they were able to take enough readings around the old backyard house before… 8 37150 |
