Browse Forums Building A New House 1 Oct 08, 2018 2:12 pm Hi All We're preparing for our plan presentation for our modified Belview with Rawson in a couple of weeks and are going cross-eyed looking at the plans trying to spot what needs to be changed etc. Does anyone have any thoughts about our design? What have we missed? Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: First time build - plan presentation prep 2Oct 08, 2018 4:47 pm Hi Catgee The design looks pretty good. How important is the toilet door in the ensuite? This comes down to my own preferences, but I'd go for a bigger shower rather than a separate toilet room in the ensuite. So i'd either 1: delete the toilet room, move it down to the bottom right corner and extend the shower to run from the vanity to the right hand wall - would be a really good size shower, could make it the same size as the bathroom shower, allowing a towel rail between it and the vanity perhaps (remember larger shower likely means more expensive with extra glass and wall tiling) Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Or 2: swap the bathroom and ensuite, moving the door to the main bedroom further into the room so you can access the Linen. This means you get a bigger shower in the ensuite, and can move the door to the toilet in the bathroom, so that it opens into the hallway. That way someone can use the toilet even if the bathroom is in use (though they'd have to find somewhere to wash their hands.) I've attached a paint edit i've done, but you can see i also moved the toilet in the ensuite to sit on the wall next to the linen. That would open the ensuite up a bit more i think. Anyway, very exciting, and looks like a good design! Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: First time build - plan presentation prep 3Oct 08, 2018 8:33 pm KingTaco Hi Catgee The design looks pretty good. How important is the toilet door in the ensuite? This comes down to my own preferences, but I'd go for a bigger shower rather than a separate toilet room in the ensuite. So i'd either 1: delete the toilet room, move it down to the bottom right corner and extend the shower to run from the vanity to the right hand wall - would be a really good size shower, could make it the same size as the bathroom shower, allowing a towel rail between it and the vanity perhaps (remember larger shower likely means more expensive with extra glass and wall tiling) Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Or 2: swap the bathroom and ensuite, moving the door to the main bedroom further into the room so you can access the Linen. This means you get a bigger shower in the ensuite, and can move the door to the toilet in the bathroom, so that it opens into the hallway. That way someone can use the toilet even if the bathroom is in use (though they'd have to find somewhere to wash their hands.) I've attached a paint edit i've done, but you can see i also moved the toilet in the ensuite to sit on the wall next to the linen. That would open the ensuite up a bit more i think. Anyway, very exciting, and looks like a good design! Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Thanks so much for the ideas, we were thinking the same thing about the ensuite - really not bothered about the toilet being separate so we'd prefer to rearrange it and get a bigger shower. Re: First time build - plan presentation prep 4Oct 08, 2018 8:56 pm Hi Catgee, looks a good plan. King Taco is on the money about a bigger shower. You could look at just moving the toilet into the place where the shower is and turn the toilet into the shower. I would also consider excising the toilet from the second bathroom and making it stand alone. If you have visitors over and someone is in the second bathroom having a shower than there is no toilet for people to use upstairs. Good luck with the choice! Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: First time build - plan presentation prep 5Oct 09, 2018 1:52 am At the plan presentation they'll also ask about the external doors you want (and also the bath for some reason) and more importantly windows.So if you want bigger windows,changed to/from fixed, sliding, awning etc, raised head heights, frosted/clear. Understand the window codes. It looks like you've set down all the wet areas, so thats good. Think about additional taps, or moving the gas point. Also think about sound proofing, anticon blanket if applicable. etc Make sure everything in the tender and variations is on the plan, ie: ceiling height, cornice detail, tiling, recessed doors That the setbacks are correct. They will pick a point on the plans and then work around every item, so make sure you know what they mean or ask at the time. Don't assume the plans are the same as the display home, for example windows might be bigger on the display home etc. Take your own notes of changes, its a long meeting and you go over a lot of things so it can be hard to keep up. Hey everyone! After lurking here for a long time and reading some amazing build journeys, I decided to document my own build to offer a blow by blow of building in Perth… 0 522 Can anyone give me any onfo on New Homes WA? Good or bad, hopefully good just need to know if my choice was good or not? Thanks ❤️ 0 4652 9 18614 |
