Change to ceiling height
Can u change ceiling height from 2.4 to 2.75m to upper level after they hav put struts up in a very small house?
Yes
We are looking to build a 2-storey 52sq home with Burbank and the 2.74m ceiling to ground and 2.4m to first floor are included as standard. We have upgraded the ceiling height to 2.59m to first floor, however I have been advised that we may have building envelope issue due to higher ceilings. I actually don't get about building envelope as the other side of the main wall of the house is 3m away from the boundary and the other side is 1.98m away.
We are thinking to leave it as is, 2.7m to ground and 2.4m to first floor since upper floor is mostly bedrooms. But I have this thinking too if we should have 2.59m each on both floors.
Thanks and hope for your inputs.
We have given two options: 2.7m to ground and 2.4m to upper floor or 2.59m on both ground and upper floors.
1
Hi, you've probably already resolved this, however, Commbank will probably pay the funds to you after you send evidence the work is done regardless the change in the quotes.
15/08/2023
5
depends on your council, some 1 day some 14 days
