Browse Forums Building A New House 1 Oct 07, 2018 3:46 pm Is anyone able to offer me some advice. i have just moved into a brand new home. Unfortunately it has many defects one of which is some significant cracking. The skirting are coming away from the tiles and large gaps are appearing. The wall is also coming away from the skirting. It is happening in several areas downstairs which is completely tiled.I initially thought it was a moisture issue but the builder doesn't think so. It also is not in the one area so this rules out a leaking toilet etc. The house is only less than two months old and I have never seen cracking like this even in an old house. I'm not sure if it is relevant, but I also have huge grout colour inconsistencies which worsens when we have wet weather. Could anyone offer some suggestions as to what it happening? Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Skirting boards pulling away from tiles and wall 2Oct 07, 2018 5:00 pm Get a inspector in this is bad you shouldnt be in this house that's not acceptable this shouldnt be happening get a inspector in straight away let him do the report and he will advise you hold on will send photos to my inspector his great will get some expert advice ok who did you build with Re: Skirting boards pulling away from tiles and wall 3Oct 07, 2018 8:51 pm kathysangel Get a inspector in this is bad you shouldnt be in this house that's not acceptable this shouldnt be happening get a inspector in straight away let him do the report and he will advise you hold on will send photos to my inspector his great will get some expert advice ok who did you build with Thanks for your reply. I built with McDonald Jones Homes. They have been an absolute nightmare to build with. No communication and Very little action in addressing the defects. In on epart of my home you can see the steel frame because the cladding has a gap between it and the brickwork. The workmanship is appalling. It's been suggested to me to get someone in to go over it and provide a report. Money is just tight at the moment for me so I've hesitated. Re: Skirting boards pulling away from tiles and wall 4Oct 07, 2018 9:31 pm wil4kat kathysangel Get a inspector in this is bad you shouldnt be in this house that's not acceptable this shouldnt be happening get a inspector in straight away let him do the report and he will advise you hold on will send photos to my inspector his great will get some expert advice ok who did you build with Thanks for your reply. I built with McDonald Jones Homes. They have been an absolute nightmare to build with. No communication and Very little action in addressing the defects. In on epart of my home you can see the steel frame because the cladding has a gap between it and the brickwork. The workmanship is appalling. It's been suggested to me to get someone in to go over it and provide a report. Money is just tight at the moment for me so I've hesitated. Re: Skirting boards pulling away from tiles and wall 5Oct 07, 2018 9:37 pm Who ever passed this house needs to be struck off who was the inspectors who passed this shody work also did you have issues with your slab I'm no builder but I have been through a lot to but my builders are fixing mine and i have had bricks pulled off my wall reenginered slab garage all redone and all windows re bricked chipped bricks I had bad brick layers so I can only advise you to get a qualified inspector I used allprocontructions they were fa tactic saved my home kathysangel wil4kat kathysangel Get a inspector in this is bad you shouldnt be in this house that's not acceptable this shouldnt be happening get a inspector in straight away let him do the report and he will advise you hold on will send photos to my inspector his great will get some expert advice ok who did you build with Thanks for your reply. I built with McDonald Jones Homes. They have been an absolute nightmare to build with. No communication and Very little action in addressing the defects. In on epart of my home you can see the steel frame because the cladding has a gap between it and the brickwork. The workmanship is appalling. It's been suggested to me to get someone in to go over it and provide a report. Money is just tight at the moment for me so I've hesitated. Re: Skirting boards pulling away from tiles and wall 7Oct 09, 2018 4:07 pm wil4kat This wasn't apparent at handover. It's getting worse each week but wasn't visible two months ago. Re: Skirting boards pulling away from tiles and wall 8Oct 09, 2018 4:09 pm kathysangel wil4kat This wasn't apparent at handover. It's getting worse each week but wasn't visible two months ago. I have and they have come to view it but haven't come back to me with how it is to be rectified. They are very slow to respond to calls or emails and often just ignore instead of replying. Building Standards; Getting It Right! Is this acceptable in a new house build. Floors where installed by builder. Already chips in board and skirting is not flush 0 183 To put anything over slate you will need to put self level compound over the entire area as slate various in thickness and is very un even. To install most types of… 1 389 |
