Browse Forums Building A New House Re: Garage and Window frame colour 6Oct 04, 2018 11:24 am Thanks TashPaul. I just had a quick look at your blog. Your place looks great! I want to get white shutters inside so am leaning towards lighter window frames. I will try the simulators mentioned above. Thanks Re: Garage and Window frame colour 7Oct 04, 2018 2:35 pm Dylemma Thanks TashPaul. I just had a quick look at your blog. Your place looks great! I want to get white shutters inside so am leaning towards lighter window frames. I will try the simulators mentioned above. Thanks We wanted a dark roof but light house, so went with Coal roof tiles, monument gutter and surfmist for fascia, windows and garage. Very happy with how it came together. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Garage and Window frame colour 8Oct 04, 2018 3:58 pm Bestspecials.... Perfect! This is exactly what I was after. I kept going back and forth between shale grey and surfmist. I emailed my builder a couple of hours ago and said monument for roof and gutters, surfmist for fascias, garage and windows. Exactly what you have! Only difference is ours won't be rendered, but so good to see yours, eases my mind a lot. Thanks Re: Garage and Window frame colour 9Oct 04, 2018 9:03 pm Dylemma Bestspecials.... Perfect! This is exactly what I was after. I kept going back and forth between shale grey and surfmist. I emailed my builder a couple of hours ago and said monument for roof and gutters, surfmist for fascias, garage and windows. Exactly what you have! Only difference is ours won't be rendered, but so good to see yours, eases my mind a lot. Thanks It is so scary when you can't see it, but we are so happy with how it has worked out. This is from the inside. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ 1 14466 Thank you every one for you input , after a lot of research and reading so many blogs decided to go with timber and brick as its the most safest option 7 3924 Its the flashing and is normal. Some builders cover them up others just leave them handing. You can cover it up with an aluminium bracket or ask the builder. 7 11167 |
