Browse Forums Building A New House 1 Sep 18, 2018 10:27 am Hi All
I need as much help as possible to where I need to go with this. Our house was due for PCI walk through on Thursday 13/9/2018 unfortunately this was cancelled last minute (20mins) due to our house being flooded out. Both toilets (a part has either been incorrectly installed or a faulty part) have had so much pressure build up and it has gone through out the whole house. At the moment no one is taking responsibility for this and head office from our builder is saying there is nothing they can do other then compensate $50.00 per day whilst fixing the problems. I have been told if I would like more compensation I would need to fight it would be with the plumber or plumbing company. Re: HELP NEEDED ASAP 3Sep 18, 2018 11:27 am The Occupancy Certification cannot be obtained until such issues are fixed and that is in your interest. Has the build duration actually/already exceeded the contract stated period? Factually the builder has given you the correct response. Play it correctly with the builder so that your work is done on priority. Hi All, I engaged a tradie to install concrete retaining wall 600-800mm high over 32 meters in Victoria. Sleepers are 200*75*2000 mm installed over 17 steel posts. I… 0 6917 Building Standards; Getting It Right! Don't think they are designed for double brick. WA has a particular way of building and unfortunately that's the way a large amount of sills are finished. 3 7014 Any structural alteration to your home requires building permit. Before you get it you will have to supply plans with structural assessment, you will also be removing… 2 4128 |
