Browse Forums Building A New House Re: Hot water service 2Sep 15, 2018 10:23 am Definitely two, one on each side. We have a similar size house with a small one on one side, feeding our daughters ensuite and downstairs bathroom, and a second larger one that services the main bathroom and our ensuite upstairs and laundry and kitchen downstairs. My hubby is a gas plumber by trade so he knows his stuff... Re: Hot water service 3Sep 15, 2018 10:35 am gogo65 Definitely two, one on each side. We have a similar size house with a small one on one side, feeding our daughters ensuite and downstairs bathroom, and a second larger one that services the main bathroom and our ensuite upstairs and laundry and kitchen downstairs. My hubby is a gas plumber by trade so he knows his stuff... Thanks for your feedback, very helpful . the sun master is the solar heating to "warm" the water in the tank the S26 is your hot water system which will heat the water (25 degrees?) so with both turned on you… 2 13542 I want to build a decking to the drawn shape outlined in black. The problem is how close can I build to the gas hot water unit? Will I be able to build around it and be… 0 20224 DIY, Home Maintenance & Repair Hi, I've got a brand new (2nd hand) Bosch Hydropower 16H tankless hot water heater. Since it was installed I have noticed it leaks a lot. I took the cover off and it looks… 0 24147 |
