Slab design - garage lower than ground level
[ltr]Question on slab designs - to meet garage height requirements our builder will need to lower my slab in the garage, resulting in the garage to be 86mm below ground level. [/ltr]
[ltr]Anyone been into a similar situation before?[/ltr]
[ltr]I'm a bit concerned about potential flooding in the garage due to being lower than ground level. How did you get around this?[/ltr]
Why are you worried about flooding? Better that you only flood the garage than the whole house!!
I had a quick look at your build thread, so it seems your land might not be titled yet, so do you not have a site plan with ground levels?
I would also presume they mean its a step down into the garage from the house, but not below the finished ground level.
Sorry my build thread is not up to date
Land has titled and settling tomorrow.
I have the site plan but it isn't finalized yet. There's still some discussions with the builder regarding changes to the site plan.
Hi g33kerb0t,
Building the Votivo43 - viewtopic.php?f=31&t=88553
Hi,
If you are seeking advice It is in your best interest to keep your build threat up to date
Your builder will adjust the levels to suit him, this may not suit you for work that you may have to do after handover, ie storm water, Runoff, Retaining ,etc.. since you only get one go at getting it right please post up the contour site plan, levels,etc for considered advice. hth
Hi,
Garages are traditionally always built one step lower than the house.
Hi Guys,
We have been told that due to higher fall on our block, we are going to have 2 steps in the garage to access home from garage door or do not obtain internal access garage door.
Without having 2 steps, It would be one big step to gain access inside.
Any thoughts or did some one come across with this issue ?
I don't think its a problem to have two steps, it may mean you have a higher ceiling in the garage which I think is handy.
One of the things I check for in pre contract review is house levels in relation to ground and drainage. Many times I have advised the client to go back to the builder for review of design levels.
I am looking to design an entry door to a lower ground basement that has 2200mm between the external entry height to FFL of the ground floor. This door will provide an…
5/02/2024
Hi there, We’ve recently had plans approved to add a 1st storey addition to our existing house for a growing family in Sydney. With the current cost of building…
18/11/2023
Hi guys, I want to do some floor levelling before laying the planks and am considering doing it with self-levelling or yellow tongue PB board. I am wondering which one…
