Hello,
We have bought a lot with a very wide frontage but not that deep. I have been trying to find a project builder with a wider plan.
Is there any hope? Did anyone come across a design Or do i go custom?
Cheers
Browse Forums Building A New House Re: Wide frontage 2Sep 06, 2018 7:56 am What state are you building? Of course there’s plenty of plans available, depending on width you could look at acreage type homes. Many builders web sites have the capacity to narrow down designs by width. Do you have favourite builders?? Re: Wide frontage 4Sep 06, 2018 8:50 am You could always look at the narrow block double storey houses and see if you can flip the garage and entry from the front narrow side to the long wide side. Re: Wide frontage 5Sep 06, 2018 9:05 am bestspecials You could always look at the narrow block double storey houses and see if you can flip the garage and entry from the front narrow side to the long wide side. That’s is what we are doing now. But I am worried about the facade of the house. Re: Wide frontage 6Sep 06, 2018 9:13 am Maybe look at style like this one? https://www.metricon.com.au/new-home-de ... oorplan=30 Re: Wide frontage 7Sep 06, 2018 9:36 am Hi Blackcat, which staircase did you choose for winchester 28 ? Is it like their one of display in winchester 34 in tarneit which looks hot but expensive, I wonder how would standard staircase looks like, Do you have any photo of your staircase ? Re: Wide frontage 8Sep 06, 2018 9:39 am Wild Hi Blackcat, which staircase did you choose for winchester 28 ? Is it like their one of display in winchester 34 in tarneit which looks hot but expensive, I wonder how would standard staircase looks like, Do you have any photo of your staircase ? Just the standard one, there are better uses of $12k+ than stairs. There should be some photos in my thread. Re: Wide frontage 9Sep 06, 2018 9:55 am Probably more options for a single storey. Also depends on budget. Plenty of builders out there that will modify there plans, or some project builders do custom designs as well (most likely cheaper than full custom) 4 4492 Hi, Seeking volume or semi-custom builder in victoria(east), which have existing double story wide floor plans. Seeking 18-20m wide homes with depth of 12-15m long. Or… 0 25163 |
