Browse Forums Building A New House 1 Aug 28, 2018 9:34 pm Hello We are currently building a double story in Point Cook and the brickwork is just horrendous. The mortar is like chalk and falls away when you touch it, bricks are not straight, some of the perpends exceed tolerance (not just by a little bit either), there are broken bricks everywhere... the list goes on.... In fact, you have to look pretty hard to find any that are done properly. We are currently in discussions with the builder and one option is to re-brick the entire house. Has anybody done this - I'd be keen to hear from anybody who has for some advice or any other info you could share. Thanks! Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ [img=335x251]https://forum.homeone.com.au/u/44001_1535455724.jpg[/img] [img=332x248]https://forum.homeone.com.au/u/44001_1535455742.jpg[/img] [img=335x252]https://forum.homeone.com.au/u/44001_1535455777.jpg[/img] [img=339x254]https://forum.homeone.com.au/u/44001_1535455836.JPG[/img] [img=334x250]https://forum.homeone.com.au/u/44001_1535455888.JPG[/img] [img=336x252]https://forum.homeone.com.au/u/44001_1535455972.JPG[/img] Re: Has anybody had to rebrick their new house? Advice? 2Aug 29, 2018 6:32 am The obvious advice is that if the builder agrees to re brick your house then get him to do it, just make sure demolition does not damage your windows. Foremost Building Expert in Australia,assisting with building problems/disputes, building stage inspections,pre-contract review advice for peace of mind 200 blogs http://www.buildingexpert.net.au/blog Re: Has anybody had to rebrick their new house? Advice? 3Aug 29, 2018 11:05 am It may also be worth having an independent business inspect your brick work for you and offer advice. If your builder is willing to redo the brickwork, then they are probably agreeing that the work isn't up to standard, just make sure that it is 100% at their cost and if there is any damage to windows or frame work that this is replaced / repaired too. Re: Has anybody had to rebrick their new house? Advice? 4Aug 29, 2018 1:12 pm HOUSPECT-Building-and-Pest-Inspections It may also be worth having an independent business inspect your brick work for you and offer advice. If your builder is willing to redo the brickwork, then they are probably agreeing that the work isn't up to standard, just make sure that it is 100% at their cost and if there is any damage to windows or frame work that this is replaced / repaired too. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Has anybody had to rebrick their new house? Advice? 5Aug 29, 2018 1:24 pm kathysangel HOUSPECT-Building-and-Pest-Inspections It may also be worth having an independent business inspect your brick work for you and offer advice. If your builder is willing to redo the brickwork, then they are probably agreeing that the work isn't up to standard, just make sure that it is 100% at their cost and if there is any damage to windows or frame work that this is replaced / repaired too. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Has anybody had to rebrick their new house? Advice? 6Aug 29, 2018 3:52 pm HOUSPECT-Building-and-Pest-Inspections It may also be worth having an independent business inspect your brick work for you and offer advice. If your builder is willing to redo the brickwork, then they are probably agreeing that the work isn't up to standard, just make sure that it is 100% at their cost and if there is any damage to windows or frame work that this is replaced / repaired too. thanks - will definitely be at their expense! Re: Has anybody had to rebrick their new house? Advice? 7Aug 29, 2018 5:47 pm kathysangel kathysangel HOUSPECT-Building-and-Pest-Inspections It may also be worth having an independent business inspect your brick work for you and offer advice. If your builder is willing to redo the brickwork, then they are probably agreeing that the work isn't up to standard, just make sure that it is 100% at their cost and if there is any damage to windows or frame work that this is replaced / repaired too. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Has anybody had to rebrick their new house? Advice? 8Aug 29, 2018 6:08 pm building-expert The obvious advice is that if the builder agrees to re brick your house then get him to do it, just make sure demolition does not damage your windows. Re: Has anybody had to rebrick their new house? Advice? 9Aug 29, 2018 6:39 pm Yes I have these are my bricks that came off I had bad brick layers that needed to go to spec savers mine are not straight all chipped different sizes i ordered them to stop bricking my home and they didnt has your bricks been acid washed with high pressure or hand washed and who's your builder Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Has anybody had to rebrick their new house? Advice? 10Aug 30, 2018 10:10 am kathysangel Yes I have these are my bricks that came off I had bad brick layers that needed to go to spec savers mine are not straight all chipped different sizes i ordered them to stop bricking my home and they didnt has your bricks been acid washed with high pressure or hand washed and who's your builder Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Our bricks have been acid washed and they have chipped many bricks and destroyed the mortar. We noticed all the issues once they were cleaned. Its is extremely difficult to actually find anywhere in the house that was done properly. Most of, if not all, bricks will need to be replaced Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Has anybody had to rebrick their new house? Advice? 12Aug 31, 2018 2:17 pm alexp79 Ah, just render them. It will be MUCH cheaper then to re-brick. At builder's expense, of course. We aren't concerned about the cost as we won't be paying for it! Mortar tests have come back and the sand was not suitable to use. So, rendering will only mask the problem. Re: Has anybody had to rebrick their new house? Advice? 13Aug 31, 2018 11:45 pm alexp79 Ah, just render them. It will be MUCH cheaper then to re-brick. At builder's expense, of course. Re: Has anybody had to rebrick their new house? Advice? 14Sep 01, 2018 12:14 am Guys, with all due respect, we are talking about brick veneer here. The bricks do not play any role other than decorative with may be some very minor weather protection. Although I agree that they are not built up to standard, but the mortar is still there and it highly unlikely that bricks will start falling out on their own. Some of the Roman Empire brick buildings still stand while bricks being in much worse shape for centuries. But yes, no doubt, re-brick still needs to be done. Re: Has anybody had to rebrick their new house? Advice? 15Sep 01, 2018 12:26 am Fresh_breath alexp79 Ah, just render them. It will be MUCH cheaper then to re-brick. At builder's expense, of course. We aconcerned about the cost as we won't be paying for it! Mortar tests have come back and the sand was not suitable to use. So, rendering will only mask the problem. Re: Has anybody had to rebrick their new house? Advice? 16Sep 01, 2018 12:36 am alexp79 Guys, with all due respect, we are talking about brick veneer here. The bricks do not play any role other than decorative with may be some very minor weather protection. Although I agree that they are not built up to standard, but the mortar is still there and it highly unlikely that bricks will start falling out on their own. Some of the Roman Empire brick buildings still stand while bricks being in much worse shape for centuries. But yes, no doubt, re-brick still needs to be done. True I'm in the process of having mine washed then all faulty brick replaced they accepted fault some bricklayers wont work with painted bricks because they chip very easily and they only recommend professional was but not pressure washed the standard of bricks have deteriorated That is a really good attitude Akin to you catch more flies with honey than vinegar. I do enjoy watching that tik tok inspector from Victoria but he does go a little… 12 81847 Versaloc is a mortarless besser block system that still needs a properly engineered footing. If you just do a 400x200 footing it will fail in time. At 17m long you need it… 1 15675 I posted the floorplan on Houzz.com forum and got some really good ideas and advice from people there. Then we reached out to a couple of renovation companies and one… 5 10083 |
