Pre wire for solar panels and Roof supporting solar panels.
Electrician will simply run a few wires from roof to near the meter box.
Double storey house so easier to pre wire it.
Not sure how true this is.. Won't a typical new house these days the roof are strong enough to support solar panels?
I read a 5kw solar panels using todays tech. is around 420kg spread along 32m2 of roof space..
Anyone could comment more on this?
The only thing they have done is put the frames up that hold the panels - not even sure if they have run any wires. The place is full of wires and I have no idea which one is which! LOL
I've just had mine pre wired - the roof question wasn't even asked.... I honestly don't think its a concern.
Did you prewire one cable for your solar or two?
I read that depending on your roof areas and designs. You may need two wires. if the panels are separated . eg. some panels facing north and some panels facing east/west.
it cost us $150.
Later when we decide to install panels they will just put their wires into prepared conduits.
no frame strengthening needed for solar panels.
I decided to run a “10mm 4 Core & Earth Orange Circular Cable” from the power box to location for the inverter and I ran 2 conduits from the bottom level roof and top story roof.
You would think I got a discount for the install wouldn’t you..
5
We already paid for somfy motors for the blinds. The quote above was purely for “pre-wiring” so the blinds company can install the motors and blinds. That’s why we…
18/07/2023
4
Just to makea point about this, an approach that some people have found sucessful in negotiating these rises down, Is to provide some workings to the builder, specifying…
7/06/2023
We've had the offer of a short term tenant whilst waiting for CDC/DA home approval and demolition for our knock down rebuild. It would achieve a pretty low rent as it's…
