Browse Forums Building A New House Re: Building on Slope -right to left 1.25m- land - suggestio 7Aug 16, 2018 6:55 am Gaudi If not open to consider split level I’d go the fill option. Higher house, More sunlight to yard and house in windows Less likely to be impacted on cut high side by shadowing by neighbors house But seek architects advice. They are the professionals and will take them not account neighboring houses, street level etc Thanks Gaudi, appreciate your suggestions, going with this option Re: Building on Slope -right to left 1.25m- land - suggestio 8Aug 16, 2018 7:07 am ratna I wouldn't proceed too far beyond the architects Sketch Without preliminary engineering Data and Construction costs Slab & Formwork Costs Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Need advice on the backyard plan above. Should I excavate and cut all of the dirt to level with the house slab or semi-excavate as per photo above? Both left and right… 0 24782 Hi All, We have recently purchased a sloping block (3.5m fall building envelope, 6m overall). Just wondering if you know of any good builders that you would recommend for… 0 1738 you need a fridgie to answer but I would think you vac the whole system then add gas if you have a leak, unless it is new install with the gas already loaded, in that case… 1 3640 |
