Hi,
My Architect has just completed the drawings, but we are stuck at finding the best option in achieving the flat back and front yard as my land is sloping from right fence to left fence by around 1.3m.
a) If we cut on right side, and build retaining of 1.3m right, then whole house level is getting almost below road level, and lower than my high side neighbour.
b) If we cut and fill, then I may have to build retaining walls both sides which cost me too much
c) If I build retaining wall of 1.3m on low side and do only Fill, then my house will be higher as well as can get flat back and front yards. By the way, do I need to do drop edge beam in this scenario?
d) Are there any other smart option that I am missing here. Appreciate your help. Thx
Split level house? What does the architect recommend?
You built on a slope, so whether you retain or do a split level, you will be forking out some extra cash. You can’t make the slope disappear, so you have to deal with it one way or another which = $$$
We wouldn't prefer split house. So wondering which of the a to c is better option
Decided to retain, but not sure which of the below retain option is best?
If not open to consider split level
I’d go the fill option.
Higher house,
More sunlight to yard and house in windows
Less likely to be impacted on cut high side by shadowing by neighbors house
But seek architects advice. They are the professionals and will take them not account neighboring houses, street level etc
Higher house,
Thanks Gaudi, appreciate your suggestions, going with this option
ratna I wouldn't proceed too far beyond the architects Sketch
Without preliminary engineering Data and Construction costs
Slab & Formwork Costs
