Browse Forums Building A New House Re: Stormwater Charged System Required? 2Aug 13, 2018 7:30 pm The Harder You Try - the Luckier You Get ! Web site http://www.anewhouse.com.au Informative, Amusing, and Opinionated Blog - Over 600 posts on all aspects of building a new house. Re: Stormwater Charged System Required? 3Aug 13, 2018 8:32 pm Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Stormwater Charged System Required? 5Aug 14, 2018 7:19 am Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Stormwater Charged System Required? 6Aug 14, 2018 10:28 am Foremost Building Expert in Australia,assisting with building problems/disputes, building stage inspections,pre-contract review advice for peace of mind 200 blogs http://www.buildingexpert.net.au/blog Re: Stormwater Charged System Required? 8Aug 16, 2018 6:17 am Your downpipes are just one issue, the other is site drainage, you should be able to have natural surface drainage to LPD, with charged system you can't. Foremost Building Expert in Australia,assisting with building problems/disputes, building stage inspections,pre-contract review advice for peace of mind 200 blogs http://www.buildingexpert.net.au/blog Re: Stormwater Charged System Required? 9Jul 20, 2019 8:18 am To rehash an old thread, I am in a similar situation. Flat block, FFL 66.325, kerb outlet 65.46. House is setback 4.5 metres and then spans 21.5m. Builder is doing charged system to two kerb outlets and looking over the stormwater plans has made a point that surface water drainage can’t be connected to the charged system (for obvious reasons) and customer is to provide alternative discharge lines for this. I’m in a conundrum as we are on a narrow block there’s not a whole lot of room for additional runs. Is it worthwhile engaging someone separate to the builder to look over everything I have and make a suggestion? Re: Stormwater Charged System Required? 10Jul 20, 2019 8:36 am tobes86 I’m in a conundrum as we are on a narrow block there’s not a whole lot of room for additional runs. On narrow difficult blocks, The last technical items should really be considered first, eg retaining,services,etc Otherwise, once the house is built, you are left in a worse position than when you started..with no alternate solution tobes86 Is it worthwhile engaging someone separate to the builder to look over everything I have and make a suggestion? Absolutely, Often stormwater is designed by the draft person, discussed at prestart by someone not qualified and correctly re-engineered later as a post contract variation at your considerable/additional cost.... OT, Siteworks should be sorted and certified up front. There is also the problem of what gets built on site, eg incorrect levels,etc hth Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Once you know the basics, the rest is easy. Read my post in the thread linked below. viewtopic.php?p=1919271#p1919271 2 19497 Plumbers 'can be' plumbers, made all the worse by self certification which the building surveyor invariably accepts as proof of compliance! The good thing is that you know know. 3 4835 Grab a hose, insert it at the top of the inlet/down pipe and turn the water on and see where the water is escaping from. Then you'll know. 3 8454 |
