Browse Forums Building A New House Re: Knock Down Rebuild - Doulton 57 Classique 107Feb 19, 2019 9:40 am Charlotte.h r_13 Looks great! Is the garage door extra wide or is the picture angle making it an illusion? We extended the garage nearly 1m. Hi Charlotte.h We are also just starting our build with Metricon Doulton in the classique facade. Just wondering if you used an independent building inspector with your build. Re: Knock Down Rebuild - Doulton 57 Classique 108Feb 19, 2019 10:05 am Yean Charlotte.h r_13 Looks great! Is the garage door extra wide or is the picture angle making it an illusion? We extended the garage nearly 1m. Hi Charlotte.h We are also just starting our build with Metricon Doulton in the classique facade. Just wondering if you used an independent building inspector with your build. No we don’t use independent inspector. My husband and I is in building industry for over 10y. So we r checking the building ourselves with help from electricians inspector and plumbing. If you haven’t started frame as yet I would recommend to upgrade to compress board to the floor in wet areas. We didn’t know that Metricon is using partical board. And check the waterproofing to the wet area. Which area/state r you building? Re: Knock Down Rebuild - Doulton 57 Classique 109Feb 19, 2019 11:20 am We are building in Keysborough, South Eastern part of Victoria. We are still in the early process and still waiting for preliminary contracts before we go to Studio in mid March. Do we still need to upgrade to compressed board even if we have Hebel power floors. Thanks. Re: Knock Down Rebuild - Doulton 57 Classique 110Feb 19, 2019 11:22 am Yean We are building in Keysborough, South Eastern part of Victoria. We are still in the early process and still waiting for preliminary contracts before we go to Studio in mid March. Do we still need to upgrade to compressed board even if we have Hebel power floors. Thanks. If you have hebel floor then no need. Re: Knock Down Rebuild - Doulton 57 Classique 111Feb 19, 2019 6:28 pm Yean Charlotte.h r_13 Looks great! Is the garage door extra wide or is the picture angle making it an illusion? We extended the garage nearly 1m. Hi Charlotte.h We are also just starting our build with Metricon Doulton in the classique facade. Just wondering if you used an independent building inspector with your build. Congrats on the start Yean. The Doulton family is growing! Start your own thread when you can so we can follow your build. Re: Knock Down Rebuild - Doulton 57 Classique 113May 19, 2019 10:18 pm Hello Folks, Glad to see a large family of DOULTON houses I am planing to build in the North, have been to SIGNATURE display house in Greenvale and Doulton display in Burwood. I have got few questions and i am positive to get replies as i can see many experts here of Doulton. This is gonna be our first building Project, i am a bit concern cause i do a lot of interstate & overseas travelling nature of my work. I am also on a Budget, by the looks of it this project is looking very straight forward however, i am sure this won't be the case, by the way we are planning for Doulton 46. 1. Base price is $435k, what you think what extra $$ if i upgrade like flooring, carpets, Kitchen,cooling etc. 2. How long the whole process will take from start till completion? 3. How much i should keep extra $$ for front yard+Back yard+ Fencing etc? 4. What kind of surprises i can face? 5. My block size is 600+SQM approx, do you think it is enough for this type of house? I am thinking of going for MODE facade to save money and spend on other things. Your suggestions will be much appreciated Re: Knock Down Rebuild - Doulton 57 Classique 114May 20, 2019 10:29 pm GTR35 Hello Folks, Glad to see a large family of DOULTON houses I am planing to build in the North, have been to SIGNATURE display house in Greenvale and Doulton display in Burwood. I have got few questions and i am positive to get replies as i can see many experts here of Doulton. This is gonna be our first building Project, i am a bit concern cause i do a lot of interstate & overseas travelling nature of my work. I am also on a Budget, by the looks of it this project is looking very straight forward however, i am sure this won't be the case, by the way we are planning for Doulton 46. 1. Base price is $435k, what you think what extra $$ if i upgrade like flooring, carpets, Kitchen,cooling etc. - I would suggest to do tiling, carpets after handover, we r doing tiling and carpet and safe a lot of money. You would need to do cooling during contraction as it’s will be more expensive after handover. Do standard lights upstairs and downlighting downstairs. Would strongly upgrade the floor in the bathrooms do not use the yellow tounge 2. How long the whole process will take from start till completion? Depends on the sale consultants for administration, admin is the longest process but you need to make sure everything is right before construction, once construction it will take between 7-10m. 3. How much i should keep extra $$ for front yard+Back yard+ Fencing etc? We r on the construction so wouldn’t know until we got handover. 4. What kind of surprises i can face? Just make sure you understand everything but best to get the independent inspection to check on the trades work as some trades are shocking 5. My block size is 600+SQM approx, do you think it is enough for this type of house? Check with the sale consultant they will put the house dimensions on the block and let you know if it’s fit. I am thinking of going for MODE facade to save money and spend on other things. Your suggestions will be much appreciated Good luck with the house Re: Knock Down Rebuild - Doulton 57 Classique 115May 21, 2019 3:34 pm GTR35 Hello Folks, Glad to see a large family of DOULTON houses I am planing to build in the North, have been to SIGNATURE display house in Greenvale and Doulton display in Burwood. I have got few questions and i am positive to get replies as i can see many experts here of Doulton. This is gonna be our first building Project, i am a bit concern cause i do a lot of interstate & overseas travelling nature of my work. I am also on a Budget, by the looks of it this project is looking very straight forward however, i am sure this won't be the case, by the way we are planning for Doulton 46. 1. Base price is $435k, what you think what extra $$ if i upgrade like flooring, carpets, Kitchen,cooling etc. 2. How long the whole process will take from start till completion? 3. How much i should keep extra $$ for front yard+Back yard+ Fencing etc? 4. What kind of surprises i can face? 5. My block size is 600+SQM approx, do you think it is enough for this type of house? I am thinking of going for MODE facade to save money and spend on other things. Your suggestions will be much appreciated 1. Base price is $435k, what you think what extra $$ if i upgrade like flooring, carpets, Kitchen,cooling etc. I would say minimum of $200k on upgrades and site costs. Would be closer to $400k if you want it like the display home. 2. How long the whole process will take from start till completion? Depends on the state you're in. QLD/SA 1 year, VIC 1.5 year, NSW 2 years+ 3. How much i should keep extra $$ for front yard+Back yard+ Fencing etc? Really depends on your land (retaining walls can cost lots) and what your plans are. $20k - $200k 4. What kind of surprises i can face? What can't go wrong... 5. My block size is 600+SQM approx, do you think it is enough for this type of house? Should fit fine, obviously depending on frontage and shape etc. Re: Knock Down Rebuild - Doulton 57 Classique 116May 23, 2019 9:24 am dulie GTR35 Hello Folks, Glad to see a large family of DOULTON houses I am planing to build in the North, have been to SIGNATURE display house in Greenvale and Doulton display in Burwood. I have got few questions and i am positive to get replies as i can see many experts here of Doulton. This is gonna be our first building Project, i am a bit concern cause i do a lot of interstate & overseas travelling nature of my work. I am also on a Budget, by the looks of it this project is looking very straight forward however, i am sure this won't be the case, by the way we are planning for Doulton 46. 1. Base price is $435k, what you think what extra $$ if i upgrade like flooring, carpets, Kitchen,cooling etc. 2. How long the whole process will take from start till completion? 3. How much i should keep extra $$ for front yard+Back yard+ Fencing etc? 4. What kind of surprises i can face? 5. My block size is 600+SQM approx, do you think it is enough for this type of house? I am thinking of going for MODE facade to save money and spend on other things. Your suggestions will be much appreciated 1. Base price is $435k, what you think what extra $$ if i upgrade like flooring, carpets, Kitchen,cooling etc. I would say minimum of $200k on upgrades and site costs. Would be closer to $400k if you want it like the display home. 2. How long the whole process will take from start till completion? Depends on the state you're in. QLD/SA 1 year, VIC 1.5 year, NSW 2 years+ 3. How much i should keep extra $$ for front yard+Back yard+ Fencing etc? Really depends on your land (retaining walls can cost lots) and what your plans are. $20k - $200k 4. What kind of surprises i can face? What can't go wrong... 5. My block size is 600+SQM approx, do you think it is enough for this type of house? Should fit fine, obviously depending on frontage and shape etc. I think you need a 16+ frontage. That price is $10.000 cheaper then what I paid. I don’t think I can answer your question on what to upgrade. I have always been one that goes overboard lol. We upgraded nearly everything. We went double our base price. All the best with your build. viewtopic.php?t=86597 Re: Knock Down Rebuild - Doulton 57 Classique 117Jul 21, 2019 11:24 pm I will also build with metricon classique facade. I am just wondering when you upgrade the first floor to 2.7m high, do we need to upgrade the facade timber window to be high? The original is 1.5m high for the first floor of 2.4m high. Re: Knock Down Rebuild - Doulton 57 Classique 118Nov 28, 2019 7:34 pm Charlotte.h r_13 Looks great! Is the garage door extra wide or is the picture angle making it an illusion? We extended the garage nearly 1m. Hi Charlotte, Could you please let me know how much did you have to pay to increase width of garage by 1m? Thanks Re: Knock Down Rebuild - Doulton 57 Classique 119Nov 28, 2019 8:01 pm Hi Tanya. Extended the garage cost us 5k as we increase the ceiling height and garage door. Are you looking to build the doulton ? Re: Knock Down Rebuild - Doulton 57 Classique 120Nov 28, 2019 8:23 pm Charlotte.h Hi Tanya. Extended the garage cost us 5k as we increase the ceiling height and garage door. Are you looking to build the doulton ? Thanks Charlotte. Yes, have had floor plan finalised and very close to signing PC. Extending garage just realised-5.55 m wont be good enough to park 2 big size cars. Have you moved to your new house? Sorry, if you already posted about it, I am new to the forum. We are building in Geelong. We've had the offer of a short term tenant whilst waiting for CDC/DA home approval and demolition for our knock down rebuild. It would achieve a pretty low rent as it's… 0 13742 Hi, First of all, thank you to this community for sharing your thoughts and opinions. We are in early days of our pre-contract stage for Metricon Doulton and we are… 0 10715 Hi I live in a 100yr old semi and my neighbour added an additional floor last yr and our architect has advised that we can knock down our semi and build a free-standing… 0 37681 |
