Browse Forums Building A New House 1 Aug 03, 2018 8:26 pm While visiting display homes of new houses recently, I was intrigued by two interesting offerings by a builder. One was called an 'Integrated Granny Flat', which is a two bedroom-livingroom-bath-kitchen set up under one roof, along with the main house. Both the main house and the 'separate quarter' are connected by a door. The flat also has its separate entry door from outside. The other one is a traditional attached granny flat, with its separate entry door. Between the main house and the granny flat there's no connecting passage. What intrigued me is that I was led to believe that the first one is Not considered a proper granny flat as such and -- this is the interesting bit -- it leaves the option open to have a detached granny flat in the backyard (assuming one passes the space requirements). Does this sound right, or have I misunderstood the sales person (I did ask twice to clarify)? Appreciate your thoughts. I would suggest you simply go and talk to council about your proposal, most councils are getting onboard with ancillary dwellings. There is no benefit in keeping it… 1 2811 I think I know the answer but just checking to see if anyone has had experience with it. I want to build a small 20 square metre retreat in my backyard, it will have a… 0 8719 Any advice on how to ensure the kit home granny flat that im thinking of buying will get council approval. The kit home companys wont release plans without a deposit and… 0 4074 |
