Browse Forums Building A New House 1 Aug 01, 2018 3:45 pm Hi everyone Just purchased a flat 720sqm block in Balwyn North and looking to build. We want a modern looking home - double storey, outdoor area & pool. Looking for suggestions or war stories on modern home builders in Melbourne. We are looking at a budget of $700-900. Have looked at smaller builders but all seem above the one mil mark. Currently looking at latitude 37 but not 100% sure. Any suggestions? Thanks Amy Modern / luxury home builder suggestions 4Aug 01, 2018 4:25 pm Comdain Englehart are probably the 2 most well known and have a lot of display houses around that area. Carter Grange is a cheaper builder which also does that kind of style. I did have initial conversation with L37 but decided they weren’t for me. With that budget you will struggle with a pool and proper landscaping. Drop that and you are closer to the mark. Re: Modern / luxury home builder suggestions 5Aug 01, 2018 5:22 pm kirashogun Comdain Englehart are probably the 2 most well known and have a lot of display houses around that area. Carter Grange is a cheaper builder which also does that kind of style. I did have initial conversation with L37 but decided they weren’t for me. With that budget you will struggle with a pool and proper landscaping. Drop that and you are closer to the mark. Thanks so much for that. I’ll look into Carter Grange and the others. We were hoping not to go with a volume builder but I think we will struggle on price. We did our current house 5 years ago with a pool and landscaping for $650 so we are hoping $800 - $900 should also get us there. Re: Modern / luxury home builder suggestions 6Aug 01, 2018 5:26 pm kirashogun Comdain Englehart are probably the 2 most well known and have a lot of display houses around that area. Carter Grange is a cheaper builder which also does that kind of style. I did have initial conversation with L37 but decided they weren’t for me. With that budget you will struggle with a pool and proper landscaping. Drop that and you are closer to the mark. Also what didn’t you like about latitude? And who did you end up with / are you happy with them? Re: Modern / luxury home builder suggestions 7Aug 01, 2018 6:12 pm GJ Gardener franchise up that area is pretty decent as well. I think at $900k for a custom builder you should be able to fit a 40sq-ish home with pretty high end finishes but might struggle to get landscaping, outdoors and pool. If you are tempted by the Metricon Signature displays, note that their base price is ridiculously high for very little included. Volume builder wise for a modern style home the Urbanedge displays and floor plans are pretty good, but I think the good sales consultants are based in the Upper Point Cook estate. Re: Modern / luxury home builder suggestions 8Aug 01, 2018 7:37 pm amyaims Hi everyone Just purchased a flat 720sqm block in Balwyn North and looking to build. We want a modern looking home - double storey, outdoor area & pool. Looking for suggestions or war stories on modern home builders in Melbourne. We are looking at a budget of $700-900. Have looked at smaller builders but all seem above the one mil mark. Currently looking at latitude 37 but not 100% sure. Any suggestions? Thanks Amy Sorry to distract from your question, but if you're within the school zone, you have hit the jackpot. You can do wonders with a 720sqm block... dual townhouses? Re: Modern / luxury home builder suggestions 9Aug 01, 2018 8:00 pm amyaims Also what didn’t you like about latitude? And who did you end up with / are you happy with them? Their presales attitude was not good and they are very expensive without a lot of quality. The basic inclusions were pretty much stock standard volume builder stuff but at custom home price. Their display home was flash but had a lot of quality problems like cupped staircase. I went with Comdain. One advantage of true custom builder is you can make changes on the fly. I literally made a cornice change 2 days before the cornice guys were going on site and they made the change without charging me any extra. It’s kind of stupid the sort of things they let you get away with. They did offer a lot of value compared to L37. Maybe have a chat to these guys. They have a display home on greythron street and a more modern one in Camberwell. I’m pretty happy overall. They are slow though as they only use exclusive experienced tradesmen so they do run into scheduling delays. They also only have one trade on at a time. But you do get quality in the end but you need to be patient. Expect 12 months build minimum. Re: Modern / luxury home builder suggestions 10Aug 01, 2018 8:03 pm derfelcadarn GJ Gardener franchise up that area is pretty decent as well. I think at $900k for a custom builder you should be able to fit a 40sq-ish home with pretty high end finishes but might struggle to get landscaping, outdoors and pool. If you are tempted by the Metricon Signature displays, note that their base price is ridiculously high for very little included. Volume builder wise for a modern style home the Urbanedge displays and floor plans are pretty good, but I think the good sales consultants are based in the Upper Point Cook estate. My problem with Metricon signature is it’s still a average quality home behind the luxe looking facade. Cheap hyjoist joists and chipboard for wall bracing, no metal braces for ceiling, waffle pod slab, 35mm internal door frames, it’s basically just an average build with some bling attached. Re: Modern / luxury home builder suggestions 11Aug 01, 2018 8:53 pm Hmmm ok awesome! I’ve heard lots of good things so far about Comdain. Did you build a modern style home? And if you don’t mind me asking what was your final cost? That’s interesting about latitude, I like their style but I’m not sure I’ve heard mixed reviews. While I think that we need to do a bigger builder to get more of what we want I think we do want to steer clear of the ‘pick a design and put it on a block’ like metricon, Henley etc. Re: Modern / luxury home builder suggestions 12Aug 01, 2018 8:55 pm meowys amyaims Hi everyone Just purchased a flat 720sqm block in Balwyn North and looking to build. We want a modern looking home - double storey, outdoor area & pool. Looking for suggestions or war stories on modern home builders in Melbourne. We are looking at a budget of $700-900. Have looked at smaller builders but all seem above the one mil mark. Currently looking at latitude 37 but not 100% sure. Any suggestions? Thanks Amy Sorry to distract from your question, but if you're within the school zone, you have hit the jackpot. You can do wonders with a 720sqm block... dual townhouses? Ha ha indeed! A surprising buy for us! It’s in the school zone which was our goal to send our little one too, so no townhouses for us! We do have a 6m easement on one side too. Re: Modern / luxury home builder suggestions 13Aug 01, 2018 8:57 pm amyaims meowys amyaims Hi everyone Just purchased a flat 720sqm block in Balwyn North and looking to build. We want a modern looking home - double storey, outdoor area & pool. Looking for suggestions or war stories on modern home builders in Melbourne. We are looking at a budget of $700-900. Have looked at smaller builders but all seem above the one mil mark. Currently looking at latitude 37 but not 100% sure. Any suggestions? Thanks Amy Sorry to distract from your question, but if you're within the school zone, you have hit the jackpot. You can do wonders with a 720sqm block... dual townhouses? Ha ha indeed! A surprising buy for us! It’s in the school zone which was our goal to send our little one too, so no townhouses for us! We do have a 6m easement on one side too. Sorry 6ft not 6m Re: Modern / luxury home builder suggestions 14Aug 01, 2018 11:07 pm amyaims meowys amyaims Hi everyone Just purchased a flat 720sqm block in Balwyn North and looking to build. We want a modern looking home - double storey, outdoor area & pool. Looking for suggestions or war stories on modern home builders in Melbourne. We are looking at a budget of $700-900. Have looked at smaller builders but all seem above the one mil mark. Currently looking at latitude 37 but not 100% sure. Any suggestions? Thanks Amy Sorry to distract from your question, but if you're within the school zone, you have hit the jackpot. You can do wonders with a 720sqm block... dual townhouses? Ha ha indeed! A surprising buy for us! It’s in the school zone which was our goal to send our little one too, so no townhouses for us! We do have a 6m easement on one side too. Ah, the easement placement. But overall, congrats on your purchase. Well done! We are also in same situation as you in regards to sourcing builders. You can inspect new builds (on sale) within your suburb or other suburbs within City of Boroondara. Inspecting new homes locally, allows you to check build quality, see trends, get ideas etc, but more importantly, if you're lucky, a business card on the table for a builder, designer, etc. Selecting a designer, architect, builder, etc who has experience with City of Boroondara helps, as they understand Council requirements. Even if you're driving around the local area(s), sometimes you see KDR and can take note of builders name. Re: Modern / luxury home builder suggestions 16Aug 11, 2018 6:35 pm Rami_m I am looking to do the same in Sydney. Any suggestions on which builders to look up? Personally, your budget will help guide your decision. Sorry for the broad advice. Volume builders like Metricon or Porter Davis offer reasonable budget pricing, but your input and control within the design process will be somewhat limited and controlled. You will choose from a set number of cookie cutter homes and make selections based on what they present you. There are boutique custom builders (but I don't know any in Sydney). More expensive than volume builders, but you have that level of customisation and flexibility within the design (of course to an extend). The selection of materials you want or prefer to use in your build will depend on how big your wallet is. Re: Modern / luxury home builder suggestions 17Aug 11, 2018 7:00 pm With building approvals sliding away it's essential to try and get some idea of your chosen builder's financial stability. Blooming hard to do but they are quick enough to want to evaluate the client's financial resource. Risk works two-way. Re: Modern / luxury home builder suggestions 18Jan 27, 2019 4:07 pm Is anyone willing to share what they paid for (per square) for a comdain or Englehart home? I’ve seen the 2 displays in Balwyn and they are beautiful (the Kooyong & Belle Vue). I’m just worried about pricing as I’m not sure it’s within our budget and I love the quality fit-out. Re: Modern / luxury home builder suggestions 19Jan 28, 2019 6:26 am Rami_m I am looking to do the same in Sydney. Any suggestions on which builders to look up? We are currently building with Tullipan homes they are based out of the central coast but build up to and hour and 15 minutes from their officers and have a few houses going up in Sydney. We have designed a custom build with them. They have been fantastic to deal with and we can’t wait to finish so we can move in. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Modern / luxury home builder suggestions 20Jan 29, 2019 8:00 pm Melos Rami_m I am looking to do the same in Sydney. Any suggestions on which builders to look up? We are currently building with Tullipan homes they are based out of the central coast but build up to and hour and 15 minutes from their officers and have a few houses going up in Sydney. We have designed a custom build with them. They have been fantastic to deal with and we can’t wait to finish so we can move in. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ I’m thinking of building with them. How much are you paying per m2? You can pm if you want:) Always handy to have the facts on hand when relying on agents advice, a lot of times sale agents advice is only good anecdotally, and when you actually dive deeper it's… 33 52675 Hi, Looking to add an ensuite to one of the bedrooms and make it a Master BR. Please see the attached current floorplan. Need suggestions on what's the best way to do… 0 7338 ideal house depends on the site and location as much as internal floor plan....what is the distance from the house to all four boundaries, where is north, describe your… 3 15157 |
