Roof trusses: 600 or 900 centers
There is a cost benefit in going 900, but I’m concerned whether that’s a wise choice.
Does 600 centers offer any benefit over 900?
Which do you recommend, and why?
provision for future solar panels or solar hot water
joejoemetoo
The trusses,Hold downs & Shear walls below will need to be designed by an Engineer
That is what is recommended by regulations.
We may add solar panels in future.
Not going with solar boosted hot water.
Our asked our structural engineer and he said he doesn’t specify the centres. Said the truss company’s engineers design the trusses to suit. I’m not sure about this.
More info required, steel or timber trusses, Flat Ceiling or raked, the bottom truss chord distances will also change your ceiling batten centres,etc,etc things to consider
You might want to read this
Slab heave is alive and well,watch out in particular the trusses.
MAKE SURE YOUR ENGINEER INSPECTS THE TRUSSES
hth
This is the case around my way. The engineer who designs the foundations (slabs, footings, piers, integrated retaining etc.) is not the same one who designs the frame and roof trusses.
Their Services are all inclusive and cheaper...hth
FEM Simulations though I doubt that your truss designer is that advanced.
OT, On the same design I also analysed Contaminant AirFlow
Rather than me trying to guess your design variables why don't you put up a floor plan, site plan, elevation remove your address, designers name,etc, more info required.Also ask your designer for a BIM 3D Model as it comes in handy, theses days they can also be used for OT, On the same design I also analysed Contaminant AirFlow
Rainfall & Stormwater Water flow can be easily calculated in a spreadsheet or as I prefer Google Sheets
The raw data comes from the BIM 3D Model and the internet; The more info you can get, the more valuable the model becomes, that applies to everything
6
Yes the knot that missing and split on the end. Turns out it needs rectification.
