Browse Forums Building A New House Hamptons inspired architect design with attached granny flat 196Feb 19, 2020 4:48 pm gogo65 What about porcelain panels? They are lighter, quantum quartz also do a 6mm thick panel for walls, assume they wont be as heavy as normal stone? Yes, this is what I’m currently looking at. We are using quantumsix for our kitchen splashback. Might actually work out cheaper! Re: Hamptons inspired architect design with attached granny 197Feb 20, 2020 12:21 pm QuantumSix+ large format tiles are great,I was very keen to use it, but endup with expensive stone splash-back option, as the builder was not very keen as 1. the tiler was hesitant as according to the tiler he was worried a minor mistake could crack the entire panel also according to him it was very hard to handle move etc. 2. kitchen and joinery company basically charged the same amount as supernatural range Caesarstone pointing that they have to double up the tile price due to the risk of cracking during cut and install. end of the day, it came down to either I have to bear the cost of any cracks during install or pay almost the same as the stone - we choose the stone. If you / your builder can find a trade comfortable and has experience working with QuantumSix+, that would be a game changer. Cheers Re: Hamptons inspired architect design with attached granny 199Mar 09, 2020 6:34 pm Not much happening inside the house these last three weeks. The Corian vanity tops have been installed, unfortunately the position of the sinks means that the top drawers of the vanities underneath cannot be used! Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Will have to think of a solution that doesn’t involve redoing the Corian. Next thing for internals are the stone bench tops, which are due 18/3. So pretty much nothing will be happening till then. Meanwhile, at least a fair bit was done in landscaping Orchard and veggie garden. Dwarf fruit trees planted, watering system installed. Concrete is for the rainwater tank Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Looking the other way towards what will be a putting green with AstroTurf Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Other side of the putting green, camellias planted to make a hedge so no one falls off the edge into the easement! Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Bit of spare area next to the orchard. We decided to concrete this and put up a basketball hoop. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Driveway poured, including steps down to front door and walkway to granny flat. It’s still to be coloured, but it won’t be too different from what it is now. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Hi all, Been browsing project builders' website and saw Masterton with attached granny flat design Seeing bad reviews from masterton in this website/facebook, does… 0 18248 I would suggest you simply go and talk to council about your proposal, most councils are getting onboard with ancillary dwellings. There is no benefit in keeping it… 1 4069 I think I know the answer but just checking to see if anyone has had experience with it. I want to build a small 20 square metre retreat in my backyard, it will have a… 0 13836 |
