Browse Forums Building A New House 1 Jul 15, 2018 9:23 am hi I need some advice , how much metres needed for a back roller door for entry into the back yard? , we don’t want A side gate for entry into the yard just the standard 1 metre side gate on other side of house. We want entry to yard from garage So how many metres is needed , is 3.5metres enough? Thank you Re: How much space needed for back entry from garage? 2Jul 16, 2018 12:29 pm Can you please clarify the question? When you say how much space, which measurement do you mean? What is your proposed 3.5 metres from & to? Is your question relating to laws & rules, or relating to useability? Maybe a little diagram might explain your question to those who may be able to answer. Black on light wood does look good. Not sure if it will be as long lasting as a steel finish? 6 6357 I am looking to design an entry door to a lower ground basement that has 2200mm between the external entry height to FFL of the ground floor. This door will provide an… 0 11383 You can really use anything you want the main consideration would be how it looks once painted/finished - or the look you want. Cabinetmakers use MDF because its cheap… 2 9980 |
