Browse Forums Building A New House 1 Jul 12, 2018 9:01 pm Does everyone know that you can run on the off peak circuit! The most suitable items are Electric Hot Water Systems (to T31) and Pool Pumps (to T33) But you can ultimately connect nearly any appliance. Think Clothes Dryers, Washing Machines and even Dishwashers. Is anyone actually taking advantage of this? Off peak electricity circuit for new build 2Jul 12, 2018 9:35 pm GLO Does everyone know that you can run on the off peak circuit! The most suitable items are Electric Hot Water Systems (to T31) and Pool Pumps (to T33) But you can ultimately connect nearly any appliance. Think Clothes Dryers, Washing Machines and even Dishwashers. Is anyone actually taking advantage of this? A controlled load tariff is not on for most of the day, so if you connect your dishwasher, etc, it will only run at certain times. Also, if you have a solar hot water system, a controlled load booster connection can work against the efficiency of that system. I couldn't attached the photo for some reason. Here is the link to the photo https://pin.it/79jwdMp 1 3120 Get some long brass machine screws and bolt right through the gate and put brass acorn nuts and washers on the other side. It will never come off 1 9082 1 2992 |
