Browse Forums Building A New House 1 Jul 11, 2018 8:47 am Dear all, My home lockup stage has just finished and I have a question about the brickwork. As you can see in the images, there is a gap between door frames and brickwork above it. Is this normal and would it be covered at some stage? On the other hand I have not seen this gap between window frames and the bricks above it. Really appreciate your thoughts about this. Thanks. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Gap between door frames and brickwork above 2Jul 11, 2018 6:17 pm Capri33 Dear all, My home lockup stage has just finished and I have a question about the brickwork. As you can see in the images, there is a gap between door frames and brickwork above it. Is this normal and would it be covered at some stage? On the other hand I have not seen this gap between window frames and the bricks above it. Really appreciate your thoughts about this. Thanks. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Bricky cant gauge to both windows and doors.95% of time doors will get an infill of the same material as the door frame. Only way out of this is to special order doors to work with windows which no hardly no one does. Re: Gap between door frames and brickwork above 3Jul 11, 2018 7:54 pm mercury10 Capri33 Dear all, My home lockup stage has just finished and I have a question about the brickwork. As you can see in the images, there is a gap between door frames and brickwork above it. Is this normal and would it be covered at some stage? On the other hand I have not seen this gap between window frames and the bricks above it. Really appreciate your thoughts about this. Thanks. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Bricky cant gauge to both windows and doors.95% of time doors will get an infill of the same material as the door frame. Only way out of this is to special order doors to work with windows which no hardly no one does. Thanks mercury10 for your reply... Cheers Re: Gap between door frames and brickwork above 4Jul 11, 2018 10:31 pm Don't panic. Ours was exactly the same and the window people did infills. You wouldn't even know. Re: Gap between door frames and brickwork above 5Jul 12, 2018 8:23 am bestspecials Don't panic. Ours was exactly the same and the window people did infills. You wouldn't even know. Thanks bestspecials and that's a relief to know. Re: Gap between door frames and brickwork above 6Jul 12, 2018 8:36 am Capri33 bestspecials Don't panic. Ours was exactly the same and the window people did infills. You wouldn't even know. Thanks bestspecials and that's a relief to know. So this is what it looked like before Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ And I don't have a photo from the outside, but if you look through the door, you can see what it looks like after Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ The yellow tape is because they are painting. Re: Gap between door frames and brickwork above 8Jul 12, 2018 9:47 am Capri33 Those pictures are helpful and your house looks great...!!! Thanks. We were a bit worried about the gap too, but now you can't even tell. 2 7525 For your reference Performance Labels: Window assemblies in housing, except timber windows, must be labelled so the label can be seen when it is in situ. For timber… 6 7713 If this is a custom build then I would expect the builder to set out the door frame closer to the wall to avoid the gap between architrave and the wall and or specify… 9 8306 |
