Browse Forums Building A New House 1 Mar 17, 2021 10:54 am hi all! we are looking at putting in an offer on a large block in the Illawarra region. its an upslope block and most of the project home companies can't help us so we are looking at custom build options. we need to build a 5 bedroom plus study home with at least 2 living areas around 350m2 total. we would also be dealing with BAL29 restrictions. anyone have any recommendations for a custom home builder who is familiar with Hamptons/american craftsmen style homes in the area that won't cost me a million dollars to build. thanks Re: upslope split level home in the Illawarra NSW 2Mar 17, 2021 3:07 pm Mrscoote hi all! we are looking at putting in an offer on a large block in the Illawarra region. its an upslope block and most of the project home companies can't help us so we are looking at custom build options. we need to build a 5 bedroom plus study home with at least 2 living areas around 350m2 total. we would also be dealing with BAL29 restrictions. anyone have any recommendations for a custom home builder who is familiar with Hamptons/american craftsmen style homes in the area that won't cost me a million dollars to build. thanks Hi Mrscoote Assuming you have a fall say maximum 6 meters you should be able to build for between $700- 800,000 depending on your design and level of finishes. The higher number will get you an absolutely gorgeous home. Just use your slope effectively to minimise excavation. BAL 29 requirements are pretty basic. I would be happy to send you a list if you like, Shouldn't add more then $5-7k to your build cost. I can also refer you to a really good designer who can do you a full package including survey, engineering, BASIX and CDC approval for around $12k that you can use to have your local builders tender off. Let me know if you want some contact details regards Simeon Simeon McGovern Affordable Custom Homes, We design and build to your budget Ashington Homes www.ashingtonhomes.com.au Re: upslope split level home in the Illawarra NSW 3Mar 17, 2021 4:53 pm Hey Mrscoote, Builders who do a lot of work in the Illawarra region with sloping blocks are Stilletto homes & Marksman Homes. They are both good builders with long reputation in the area. Cheers Move your linen into laundry and access laundry from your present linen space 1 8500 having built on acres several times i suggest that you also need to add the cost of a sewerage system and any associated fencing, water tanks with associated extra… 2 2482 isn't a garage level with the rest of the house a given? pretty sure they 'came around' long time ago. if you have a flat block, the garage is usually level with the rest… 1 18317 |
