Browse Forums Building A New House Re: Frame or pre plaster inspections? 3Jun 30, 2018 3:20 pm arcadelt If you leave the frame to be inspected until after services are installed, then those will need to be dismantled if the frame needs to be redone in any area. Thanks Arcadelt! I didn't think about that one! This is 100% true. You can not hang anything on steel frames. very frustrating 8 8008 You have mandatory building inspections and privately engaged building inspections. The difference between the two comes down to inspecting the building so it's safe and… 3 18063 Hi, Have used the Dulux 1 step, oil base on my walls(white set), out of can it’s already a more thinner product than a final coat paint Also in water base Water or… 3 5024 |
