Browse Forums Building A New House 1 Jun 26, 2018 11:59 pm Hi, Does anyone have flood study map for Bardia. I am building on Alamean street. does this Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ area has any special requirement? can someone send me their floor level advise from campbelltown council? i got these advise from council. is it normal to have advise like this photo? Re: Bardia Flood study map, floor level advise 2Jun 27, 2018 12:03 am what is meaning of adjoining finished ground level? does this mean garage level? or level after builder cut or fill the land? Re: Bardia Flood study map, floor level advise 3Jun 27, 2018 5:29 am We have the same clause in our 88b certificate over in Willowdale with Campbelltown Council. It meant that we had to add an extra course of bricks below the ground floor storey to elevate the house. Cost us about $3000 with our builder. The reference to finished floor level is for the ground floor rooms, not the garage which is lower. Building Wisdom Aspiration 31 at Willowdale https://ourwillowdalehome.wordpress.com/ Re: Bardia Flood study map, floor level advise 4Jun 27, 2018 8:47 am Hi Jennifermarie, When I checked on google it says habitable area are living room,kitchen,bed room etc.. So I am thinking if I am not dropping my garage too much still my house need to be at least 300 mm above garage. And also on sides 300 mm above level of ground. Re: Bardia Flood study map, floor level advise 5Dec 06, 2018 6:33 pm wenty to bardia Hi, Does anyone have flood study map for Bardia. I am building on Alamean street. does this Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ area has any special requirement? can someone send me their floor level advise from campbelltown council? i got these advise from council. is it normal to have advise like this photo? Hi Wenty, Did you do raised slab or did you do drop edge beam for your garage ? Re: Bardia Flood study map, floor level advise 6Dec 06, 2018 7:27 pm thecube wenty to bardia Hi, Does anyone have flood study map for Bardia. I am building on Alamean street. does this Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ area has any special requirement? can someone send me their floor level advise from campbelltown council? i got these advise from council. is it normal to have advise like this photo? Hi Wenty, Did you do raised slab or did you do drop edge beam for your garage ? Hi Got drop edge beam. My garage need to be 3step lower then house so I keep 2 step in garage and one in laundry. Where are you building and with whom ? isn't a garage level with the rest of the house a given? pretty sure they 'came around' long time ago. if you have a flat block, the garage is usually level with the rest… 1 17525 Yes it had a house on it. But Melbourne water only wanted something the original size of the existing house. We managed to fit a 45sq house on. 10 33655 Give Jonathan a call. Tell him you know me. He is in my opinion the best surveyor I have ever worked with. His number is 0425 285 622 All the best Simeon 3 12392 |
