Browse Forums Building A New House 1 Jun 02, 2018 9:45 pm Hi, I’m about to purchase a parcel of land that I understand was register late 2017. The Deposited Plan is dated August 2017 but I am under the impression that it was registered later in 2017. However i do need help clarifying: 1. What are the dotted lines representing on the plan that crosses through several lots? 2. How do I find out when the lot was actually registered? Thanks in advance.(getting stressed) Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Need help understanding Deposited Plan! 2Jun 02, 2018 11:36 pm GLO 1. What are the dotted lines representing on the plan that crosses through several lots? Dotted lines are likely to be sewer or stormwater lines. Chances are, therefore, those blocks have easements for access if required. You can check that as it will be listed in any contract documentation. Re: Need help understanding Deposited Plan! 4Jun 03, 2018 8:06 am Glo Check, The developers civil engineering drawings and get proper advice The quotes I am seeing at the moment are ridiculously expensive..goodluck Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Need help understanding Deposited Plan! 5Jun 03, 2018 8:26 am Hi StructuralGuy, Thanks for your reply. Is that something the Project Home builder would have access to? I have attached the Sydney Water (Dial before you dig) plans. No easements shown there. But I'm not even 100% sure where that's supposed to be shown or obtained now! I requested from Council the Section 149 (now called section 10.7) which I thought was the correct document to request. But that included no map or easement diagrams. I was then referred to LPI to get the Deposited Plan, but again that shows the dotted line crossing the property. I'm stuck in an endless loop and the legal team from the developers seem to be treating this as an un-registered block.ie sending the DP for the parent pre-subdivision block. Naturally they (the developer) would have updated infrastructure plans to obtain the registered block status, but I can't get it. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Need help understanding Deposited Plan! 6Jun 03, 2018 8:34 am Employ your own civil engineer to find it all out for you. GLO Hi StructuralGuy, Thanks for your reply. Is that something the Project Home builder would have access to? I have attached the Sydney Water (Dial before you dig) plans. No easements shown there. But I'm not even 100% sure where that's supposed to be shown or obtained now! I requested from Council the Section 149 (now called section 10.7) which I thought was the correct document to request. But that included no map or easement diagrams. I was then referred to LPI to get the Deposited Plan, but again that shows the dotted line crossing the property. I'm stuck in an endless loop and the legal team from the developers seem to be treating this as an un-registered block.ie sending the DP for the parent pre-subdivision block. Naturally they (the developer) would have updated infrastructure plans to obtain the registered block status, but I can't get it. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Need help understanding Deposited Plan! 8Jun 03, 2018 9:12 am GLO . Naturally they (the developer) would have updated infrastructure plans to obtain the registered block status, but I can't get it. The developers & Builders aren't going to tell you anything....? Go to the source phone the water authority and ask to speak to an Engineer They will advise you of probable outcomes If it stinks... no need to taste it hth Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Need help understanding Deposited Plan! 9Jun 03, 2018 5:27 pm GLO Hi, I’m about to purchase a parcel of land that I understand was register late 2017. The Deposited Plan is dated August 2017 but I am under the impression that it was registered later in 2017. However i do need help clarifying: 1. What are the dotted lines representing on the plan that crosses through several lots? 2. How do I find out when the lot was actually registered? Thanks in advance.(getting stressed) Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Can you post the full page of the DP? The registration date of the deposited plan will be in the sheet of the registered plan Re: Need help understanding Deposited Plan! 10Jun 03, 2018 8:50 pm Isitbuiltyet GLO Hi, I’m about to purchase a parcel of land that I understand was register late 2017. The Deposited Plan is dated August 2017 but I am under the impression that it was registered later in 2017. However i do need help clarifying: 1. What are the dotted lines representing on the plan that crosses through several lots? 2. How do I find out when the lot was actually registered? Thanks in advance.(getting stressed) Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Can you post the full page of the DP? The registration date of the deposited plan will be in the sheet of the registered plan Thanks, I can see that it’s August 28, 2017. I was advised today that the cross lines are in fact markers to aid in postioning the house on the land. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Need help understanding Deposited Plan! 11Jun 04, 2018 8:12 am And it's just coincidence that they line up with PVC pipes? Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Need help understanding Deposited Plan! 13Jun 04, 2018 5:45 pm GLO Isitbuiltyet GLO Hi, I’m about to purchase a parcel of land that I understand was register late 2017. The Deposited Plan is dated August 2017 but I am under the impression that it was registered later in 2017. However i do need help clarifying: 1. What are the dotted lines representing on the plan that crosses through several lots? 2. How do I find out when the lot was actually registered? Thanks in advance.(getting stressed) Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Can you post the full page of the DP? The registration date of the deposited plan will be in the sheet of the registered plan Thanks, I can see that it’s August 28, 2017. I was advised today that the cross lines are in fact markers to aid in postioning the house on the land. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Correct. They are the reference points used by the surveyor in the land subdivision. See here for more info (http://rg-guidelines.nswlrs.com.au/depo ... ence_marks) You won’t find details of plumbing on the deposited plan, just easements for drainage and sewer and the like. Did you resolve wether or not the land is registered? Sometimes on a large development It will be staged in multiple sub divisons Re: Need help understanding Deposited Plan! 14Jun 07, 2018 10:23 pm Hi, The land was registered Aug 28, 2017. No easements can be seen on Dial before you dig: 1.sydney water map. 2. Endeavour energy 3.Jemena 4.NBN 5.Telstra. If anything was there, it would have shown Up in any of those 5 right? Re: Need help understanding Deposited Plan! 15Jun 09, 2018 2:06 pm GLO Hi, The land was registered Aug 28, 2017. No easements can be seen on Dial before you dig: 1.sydney water map. 2. Endeavour energy 3.Jemena 4.NBN 5.Telstra. If anything was there, it would have shown Up in any of those 5 right? If there were any easements, yes. They have to be registered on the title, and would appear on the plan. Services won’t appear on the deposited plan- they will be on the dial before you dig results Re: Need help understanding Deposited Plan! 16Jun 09, 2018 2:09 pm Sydney water’s sewer and drainage diagrams would show those services Re: Need help understanding Deposited Plan! 17Jun 16, 2018 9:02 pm Isitbuiltyet Sydney water’s sewer and drainage diagrams would show those services Does that mean there would be another set of plans to request from Sydney Water ( than what I have posted earlier)? ask the surveyor for clarification would be the logical approach 1 20124 6 55311 This is a very tight fit, I'm not sure if you'll be able to achieve what you've described. Would you consider accessing the separate toilet from the laundry? If so maybe… 1 11228 |
