Browse Forums Building A New House Re: Decking new Alfresco 2May 30, 2018 9:14 pm Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Decking new Alfresco 10May 31, 2018 4:32 pm I have to agree with not attaching decking directly to an alfresco slab. The moisture trapped within it over time will shorten its lifespan and you will be ripping it up in no time due to rot. There are a number of solutions to decking over a concrete alfresco slab, however, not a lot of them will fit within 50mm of height between alfresco slab height and your internal finished floor height. As a suggestion, but by no means the only or best solution could be adjustable decking pedestals to place your joists on. You need to remember that an alfresco slab is not the most accurate of surfaces and it may have a decent gradient towards the outside edge. You will need more height that 50mm for any solution you choose so if its not too late I'd be talking to the builder and have a larger difference between internal and alfresco slabs. Its better to have height to fill than no height to work with at all. my 2 cents. Re: Decking new Alfresco 11Jun 30, 2018 1:09 pm We are now deciding whether to continue with decking or go timber look tiling. Timber look tiling is alot cheaper and would not need the maintenance that you need with timber. something like the below. Has anyone done this? https://www.nationaltiles.com.au/woodma ... ernal-tile Re: Decking new Alfresco 12Jul 01, 2018 11:07 am Trent Smith We are now deciding whether to continue with decking or go timber look tiling. Timber look tiling is alot cheaper and would not need the maintenance that you need with timber. something like the below. Has anyone done this? https://www.nationaltiles.com.au/woodma ... ernal-tile What’s your internal surface going to be that adjoins the alfresco? Re: Decking new Alfresco 13Jul 01, 2018 1:22 pm gillybean Trent Smith We are now deciding whether to continue with decking or go timber look tiling. Timber look tiling is alot cheaper and would not need the maintenance that you need with timber. something like the below. Has anyone done this? https://www.nationaltiles.com.au/woodma ... ernal-tile What’s your internal surface going to be that adjoins the alfresco? Floating timber floors Re: Decking new Alfresco 14Jul 01, 2018 2:14 pm Trent Smith We are now deciding whether to continue with decking or go timber look tiling. Timber look tiling is alot cheaper and would not need the maintenance that you need with timber. something like the below. Has anyone done this? https://www.nationaltiles.com.au/woodma ... ernal-tile Hi Trent the tiles look good. Do you know how much would be installed cost per sq m including installation. As you mentioned this would be cheaper than the deck. Cheers ! Re: Decking new Alfresco 15Jul 02, 2018 8:57 pm Ozshaz Trent Smith We are now deciding whether to continue with decking or go timber look tiling. Timber look tiling is alot cheaper and would not need the maintenance that you need with timber. something like the below. Has anyone done this? https://www.nationaltiles.com.au/woodma ... ernal-tile Hi Trent the tiles look good. Do you know how much would be installed cost per sq m including installation. As you mentioned this would be cheaper than the deck. Cheers ! Not sure at this stage, but materials alone is nearly half the price of the timber materials. Re: Decking new Alfresco 16Jul 20, 2018 2:21 pm We had this debate with our sales consultant and at our final selections appointment we changed from a 50mm to a 70mm drop, it cost us $250 because another engineers report was needed. They wouldn't let us have the drop any more than 70mm. It might come to us having to sand down the timbers right next to the door frame so we can slide it under the door frame. We found out that Dechellis rebate the sliding doors but couldn't tell us by how much so hopefully we can make 70mm work. Re: Decking new Alfresco 17Jul 20, 2018 7:49 pm NicolleAW We had this debate with our sales consultant and at our final selections appointment we changed from a 50mm to a 70mm drop, it cost us $250 because another engineers report was needed. They wouldn't let us have the drop any more than 70mm. It might come to us having to sand down the timbers right next to the door frame so we can slide it under the door frame. We found out that Dechellis rebate the sliding doors but couldn't tell us by how much so hopefully we can make 70mm work. Thanks for this very useful, we are going to end up tiling it now ☺ Re: Decking new Alfresco 18Oct 08, 2018 6:44 am Not sure if anyone has requested this on their build but is it possible to have a no step down to alfresco? We are looking to tile our alfresco too but I think it looks better if the floor level is the same as the house? Thanks Re: Decking new Alfresco 19Oct 08, 2018 4:10 pm Melbournevic Not sure if anyone has requested this on their build but is it possible to have a no step down to alfresco? We are looking to tile our alfresco too but I think it looks better if the floor level is the same as the house? Thanks I think that's what everyone's been talking about above - you'd need to rebate the door tracks, and then either have your alfresco slab at the same height as your internal slab to then tile it, or do this 100mm lower to allow clearance to put the decking down. Definitely can do it though, and it looks a treat Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Decking new Alfresco 20Oct 08, 2018 4:46 pm KingTaco Melbournevic Not sure if anyone has requested this on their build but is it possible to have a no step down to alfresco? We are looking to tile our alfresco too but I think it looks better if the floor level is the same as the house? Thanks I think that's what everyone's been talking about above - you'd need to rebate the door tracks, and then either have your alfresco slab at the same height as your internal slab to then tile it, or do this 100mm lower to allow clearance to put the decking down. Definitely can do it though, and it looks a treat Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Thanks KingTaco, that looks really good. Hi, as per the subject. Does anyone have any recommendations for the best value decking oil (Bunning is close to where I live) for a treated pine deck? Thanks 0 10973 Hello! I've alfresco pitch of 3 degrees sitting just below the highlight window. Need advice on below: 1. Will the 3 degree pitch be ok to drain the rain water? The roof… 0 4199 Use a product like Equisol's Vitalise to clean the deck then coat with a penetrating timber oil. It will look 10 years younger and add value to your home. Visit for… 1 15796 |
