Hebel overhang
WaldorfMM
That is but one solution make sure any steel angle section & Bolts are Hop Dipped Galvanised..hth
well they certainly didn’t do that. I know they put some sort of cement to widen the slab and then rendered over it. Have asked my building surveyor to reinspect.That is but one solution make sure any steel angle section & Bolts are Hop Dipped Galvanised..hth
13
In the end, two pieces of treated timber (20mm thick) were bolted onto the joists and planed when there was too much sticking out. Passed inspection.
14/09/2023
4
Thanks Ardo, they are sort of semi concealed. I think it is only a few millimetres. I see if they can adjust the hinges.
10/05/2023
I was looking at different options for a fence for my build and Hebel PowerFence seemed like a good option (one of the criteria was a solid wall look). However, I don't…
