Browse Forums Building A New House Re: Waffle slab know what your getting. 2May 23, 2018 7:49 pm Joker https://www.cornellengineers.com.au/beware-waffle-slabs/ Great information from Matthew Cornell, full marks I have inspected close to 10000 homes either during construction or finished at various ages for pre purchase or defect inspections. My firm belief is that regardless of theory, in practice the waffle pod slabs are a lot closer to risk edge cliff than conventional raft slabs and I would avoid them whenever possible. Whatever cost and operational advantage waffle slabs are to the builder it is not passed on to the owner and instead owner takes up the much higher risk of failure for no benefit at all. I have just come off pre plaster inspection of a large 2 storey home KDR on a P site and despite my warnings to the builder from the beginning there are no temporary downpipes installed, so I am just collecting evidence as it may be needed later. Foremost Building Expert in Australia,assisting with building problems/disputes, building stage inspections,pre-contract review advice for peace of mind 200 blogs http://www.buildingexpert.net.au/blog Re: Waffle slab know what your getting. 3May 24, 2018 4:28 pm My builder told me not many do concrete piers underneath of slab. Our builder and slab engineer has put at-least 20 concrete piers before doing slab which I believe is waffle slab. Property being built literally next to us are having significantly less concrete piers. How this can be possible as I would have thought their soil type etc. would be same as ours. I must say it's a house and land package though. Looking to build a home in VIC. Land titled in November 2017. Construction started in February 2018. Double storey 37sq. Re: Waffle slab know what your getting. 4Jun 17, 2018 9:23 am Loveguru Property being built literally next to us are having significantly less concrete piers. How this can be possible as I would have thought their soil type etc. would be same as ours. Geo1 is a forum member who is also a very good geotechnical engineer with a social concience. Go to his profile page to access all of his posts and read through those to find the possible/probable answer to your question but other factors may also be in play. Reading the thread below would be a great start. viewtopic.php?f=1&t=91741&p=1805661#p1805661 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. The Soil classification has little to do with piers. The purpose of the classing of the soil is to identify the clay content and the "average expected range of movement… 2 10125 Use a product like Equisol's Vitalise to clean the deck then coat with a penetrating timber oil. It will look 10 years younger and add value to your home. Visit for… 1 16161 How much are you ahead in payments compared to where the build is at? Have you fully drawn down the loan? 5 12172 |
